Best Method For Framing Low Ceilings - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-08-2013, 10:08 AM   #1
Rewards Points: 119
Best method for framing low ceilings
I am in the process of finishing my basement and am down to the bathroom ceiling prior to drywall. Due to dust work and i-beam the ceiling in this area is low. I need some sugested methods to frame this without loosing to much height.
KStatefan is offline   Reply With Quote
Old 04-08-2013, 11:11 AM   #2
Always learning...
fetzer85's Avatar
Rewards Points: 262
Can you screw drywall directly to the floor joists or is electric/plumbing/etc in the way? Please post some pictures.
fetzer85 is offline   Reply With Quote
Old 04-08-2013, 11:17 AM   #3
Rewards Points: 119
HVAC and supply plumbing is in the way.
I was thinking something like this. Since I can get the span I need.
Old 04-08-2013, 12:17 PM   #4
Always learning...
fetzer85's Avatar
Rewards Points: 262
Would 2x4's give you enough clearance? If so I'd just frame it around the hvac and lay the 2x4's on the flat across the joists.
Old 04-08-2013, 02:25 PM   #5
Rewards Points: 119
I will take pictures tonight. The entire ceiling in the bathroom will be the same height. What kind of span can a flat 2X4 be used on?
Old 04-08-2013, 03:37 PM   #6
GBrackins's Avatar
Rewards Points: 2,108
if the 2x4's are attached to each joist you will have no issues
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 04-08-2013, 04:08 PM   #7
Rewards Points: 119
The joist are covered with HVAC duct work.
Old 04-08-2013, 04:24 PM   #8
Framing Contractor
Rewards Points: 120
A flat 2x4 will span maybe 4'
sixeightten is offline   Reply With Quote
Old 04-08-2013, 06:09 PM   #9
Rewards Points: 119
Here is the picture of the ceiling. I need to span 5 feet for the width of the bathroom.
Old 04-08-2013, 06:15 PM   #10
Framing Contractor
Rewards Points: 120
I think I would space the flat 2x4's on 12" centers and make sure they are crowned upwards. Probably not up to snuff engineering wise, but if not, I bet it is real close and should work ok.
Old 04-08-2013, 06:40 PM   #11
retired union carpenter
Send a message via Yahoo to coupe
the hat track in first picture will work if 3/4" is satidfactory?
good luck
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
Old 04-08-2013, 08:21 PM   #12
Rewards Points: 119
good luck
That is why I thought that would be the best since it is the lowest profile I have found.
Old 04-08-2013, 08:26 PM   #13
Framing Contractor
Rewards Points: 120
Can hat channel span 5'?
Old 04-08-2013, 08:31 PM   #14
Rewards Points: 119
According to the catalog yes depending on spacing, load and allowable deflection.
Old 04-09-2013, 06:53 AM   #15
Not so new
12penny's Avatar
Rewards Points: 520
Hat track will be fine. I would run another piece, screwed on top of them, perpendicular, and tied into the ceiling joists above. You can use short pieces of track or, if you dont have room, I've used drop ceiling wire. This approach will hold up the center of your ceiling and prevent it from bowing downward.
12penny is offline   Reply With Quote
crown install - method for ceiling edge attach firstimereno Carpentry 2 08-30-2012 06:58 PM
insulation in slanted ceilings dhonn Insulation 10 05-05-2011 12:38 AM
Need help choosing the easiest method for skim coating fortunecookies Drywall & Plaster 2 03-05-2011 03:09 PM
Covering Radiant Heat ceilings. Hockeynews Remodeling 3 04-10-2009 08:23 AM
