Best Material For Shop Wall Covering? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-20-2009, 12:40 AM   #1
best material for shop wall covering?
Just got done pouring the slab for my shop, am planning on stick frame construction with sheet metal/colored tin for the outer covering and insulating and covering the inner walls. Since I will be doing a lot of grinding and such and fire is a potentail hazard I had thought of sheet rock, and maybe put something like trim coil on the wall behind the work benches.
What other material would be good? Needs to be smooth and somewhat fire resistant, at least as much as say drywall, and economicle, read cheap.
will52100 is offline   Reply With Quote
Old 02-20-2009, 06:43 AM   #2
Mold!! Let's kill it!
Rewards Points: 2,012
You can hardly beat drywall for fire resistant and cheap.
Old 02-20-2009, 09:03 AM   #3
Thanks, about what I figured, but thought I'd see if there was anything else out there I didn't know about.
Old 02-20-2009, 11:57 AM   #4
Rewards Points: 1,910
I was in Menards the other day and they had a steel siding intended for use as interior wall covering. You could put that over osb. I don't think osb is required but I would use it for "dent reduction" and to make it easier to hang things. Obviously a lot more expensive than drywall.
Old 02-20-2009, 01:28 PM   #5
Rewards Points: 562
with the metal you could 'clean' it of fly specs and other stuff. IF you drywall it,you still need osb or plywood behind to hang stuff on!!
4just1don is offline   Reply With Quote
Old 02-20-2009, 02:45 PM   #6
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,638
Ayuh,...
I cut,+ weld, Alot...
You just can't beat metal lined walls for fire safety...
Old 02-20-2009, 05:49 PM   #7
Thanks, figured on thin metal 2' strips around bench top hight. Majority of hot work will be outside under the drop shed, outside walls will be metal roofing and gravel floor so no fire hazard there. Inside will be some grinding, mostly machine work and hand finishing. Probably worrying over nothing, but mainly don't want dust to acumulate in rough surfaces. Even though hot work will be out side there will be the posability of fire from heat treat and solder/brazing. Also titanium dust can be very flamable and extreamly hard to put out, that's one reason I rejected particle board, too many nooks and cranies for it to build up in.
Old 02-20-2009, 10:14 PM   #8
Rewards Points: 1,016
pegboard
I installed the heavy 1/4" thick pre-primed pegboard on the walls of my 24x30 workshop/garage. Inexpensive, looks good, functional, and went up quickly.
Vince
Built-in cabinets/shelves in bonus-room knee wall flamtap Remodeling 2 10-26-2009 09:14 AM
How to diagnose problems with wall kahlan General DIY Discussions 5 10-22-2008 09:18 AM
Low Retaining Wall cibula11 Landscaping & Lawn Care 3 07-29-2007 12:02 AM
Strange Wall Material Under Shower Tile caphill General DIY Discussions 4 07-23-2006 09:50 PM
What roofing material is right for me? Grumpy Roofing/Siding 0 07-07-2004 07:41 PM
