Old 04-08-2010, 10:19 PM   #1
Best insulation for 'cool room'
Hi!
It's common in the beer and wine world to want a coolish fermentation room.
Basically it has to be about 61-64 degrees inside the room (or area). Many use an air conditioner for this and setup these rooms in the basement.
The problem is the insulation. Everyone is doing something different.
Should I be using fiberglass? Styrafoam?
What would keep in cool temps the best?
mikedavid00 is offline   Reply With Quote
Old 04-08-2010, 10:27 PM   #2
Xtreme DIY'r
Where are you located ?
Are you building this in a basement ?
Old 04-08-2010, 10:44 PM   #3
Yes sir. Not an actual room.. more of a big closet sort of space.
advice/Help on non-permitted bonus room? Orange_County General Discussion 43 06-11-2010 06:06 PM
Adding attic insulation pomelo Building & Construction 3 10-22-2009 06:19 PM
How hard to install insulation yourself? techprincesse Building & Construction 26 10-17-2009 10:57 AM
Old home insulation woes nowwhatnapster Building & Construction 15 11-03-2008 12:59 AM
Heat pump in non insulated nor heated room robdville HVAC 3 01-21-2008 03:51 PM
