Best Furring Strips? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-02-2006, 10:33 AM   #1
They're all fixer-uppers
J187's Avatar
Rewards Points: 506
Best furring strips?
I need some 1/4" furring strips to fur out the studs in my bathroom. All I can find at Home Depot are precut 4' sections that seem almost like balsa wood. What's the best material to use for furring strips and can I avoid having to cut them to the 11/2" width to go over the 2x3 studs?
J187 is offline   Reply With Quote
Old 06-02-2006, 11:26 AM   #2
Darylh's Avatar
Doesn't really matter what the furing srtips are made of because all they are is backing. Your fasteners go into your studs and thats what is important.
Darylh is offline   Reply With Quote
Old 06-02-2006, 01:01 PM   #3
If you have a table saw then just take a 2x4 and cut the width that you need for the shim. If you need an 8 foot long shim then cut the 2x4 (8 foot long) the full length at the 1/4 thickness. Cheaper to buy one 2x4 and cut it then to buy shims. You can cut custom wide shims this way.
redline is offline   Reply With Quote
Old 06-02-2006, 05:26 PM   #4
J187's Avatar
Rewards Points: 506
Thanks, I don't have a table saw though.
Old 06-03-2006, 08:10 AM   #5
Ask a neighbor or a friend with a table saw to cut you what you need.
Old 06-03-2006, 10:41 AM   #6
Darylh's Avatar
Why don't you mount a skill saw to a piece of 3/4" plwood with a slot cut for the blade then flip it upside down and clamp to some saw horses and then just clamp a piece of 1x4 for a fence. Instant table saw.
Black strips on wallboard mounted on metal studs regman Building & Construction 4 07-20-2007 11:07 PM
Best way to handle this - furring out concrete freeze wall J187 Building & Construction 10 05-14-2007 06:17 PM
Recommended way to attach firring strips to Drylock wall? jbwaechter Building & Construction 1 04-29-2007 05:08 PM
No starter strips fishwi Roofing/Siding 4 10-12-2005 10:32 AM
