Best Flooring For Basement! - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-14-2012, 07:11 PM   #1
Best flooring for basement!
I am gutting my poured concrete basement an was wondering two things... Firstly, what type of flooring should I be using( especially if I want to use carpet)... An second, what type of vapor barrier do I use on the walls... Or is spry foam my best bet? I appreciate any help! Thanks and happy holidays!!!
stoked91 is offline   Reply With Quote
Old 12-14-2012, 07:30 PM   #2
Rewards Points: 2,516
Ahhh I would say carpet.
hammerlane is offline   Reply With Quote
Old 12-14-2012, 11:16 PM   #3
Rewards Points: 956
i say never carpet. it gets super nasty,especially in basement it can get moldy. even worse
federer is offline   Reply With Quote
Old 12-15-2012, 12:17 AM   #4
Rewards Points: 1,092
Firstly, what type of flooring should I be using...•• First, ensure that your floor is dry. If not, then I'd not put anything on it. If dry, it depends on how cold it is. Some people put rigid foam down, then flooring; there are various permutations of that. Avoid vapor barrier flooring, like vinyl, unless you are absolutely positive it is absolutely dry absolutely all the time.... which you absolutely can't.
An second, what type of vapor barrier do I use on the walls...•• None below grade. Put a vb on the floor if you desire.
Or is spry foam my best bet? •• Rigid foam is probably the best on basement walls. Search here for "basement wall insulating".
see after bullets.
How to Install Semi Solid Oak Flooring jastin123 Flooring 0 07-18-2012 11:51 PM
asbestos in our ripped up flooring?? 6fthook Flooring 16 07-29-2011 11:06 PM
Installing Hardwood Flooring on Concrete Flooring, Condo slickwilly789 Flooring 1 10-08-2010 08:53 PM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 08:00 PM
