11-15-2008, 02:46 PM
#1
Best (easiest) way to drill into poured concrete wall
I am trying to drill a pilot hole for a masonry screw into my basement concrete wall.
I purchased a 3/16" masonry drill (with carbide tip) and after some serious effort, was able to drill the first of four holes approximately 2 1/4" deep.
Got the other three started... but then they sort of quit making progress....
First hole, I used a DeWalt 14 XRP cordeless drill motor.... then, because the subsequent holes were wearing me out... I switched to a corded drill motor...much faster rpm, but still making little to no progress in deepening the holes.
Suggestions??
Thanks.
11-15-2008, 02:49 PM
#2
You talking to me?
a hammer drill
11-15-2008, 02:53 PM
#3
All trades carpenter
Hammer drill and maybe a little water to cool the bit down.
11-15-2008, 03:02 PM
#4
Don't know it all, yet!
A funny thing happened on the way to the forum-
OK, so that was a movie.
Here's the story:
I tried for several years to convince my boss we needed a hammer drill in the shop. I do parks maintenance. We have a mechanic but I am involved in the parks aspect, i.e. playgrounds, etc. For example, one day I was installing a park bench onto a sidewalk. I needed four holes for lag bolts. Burned up a "good" bit per hole, even with watering to keep cool. Same story many times on different projects. A few weeks later the boss stops by HD one Friday and gets a Bosch hammer drill. Takes it home to drill some holes in the concrete wall in his basement to put up some studs. Where have I heard this before? Oh yeah. He comes in Monday morning grinning like a cat with a bird. "Now I know why you wanted a hammer drill!" Thirty seconds of him using it convinced him better than my two years of nagging.
'Nuff said.
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
11-15-2008, 03:30 PM
#5
You probably hit a rock dead center. Hard to drill through those.
As others have said the only way to fly is a hammer drill. It will get through that in no time at all.
My idea of a perfect day: No where to go and all day to get there.
11-15-2008, 04:46 PM
#6
You talking to me?
Originally Posted by downunder
'Nuff said.
maybe after a couple "idiot"s under my breath along with a slap upside his head.
11-15-2008, 04:51 PM
#7
Drywall contractor
Ditto on the hammer drill!
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
11-15-2008, 04:56 PM
#8
Here's the story:
'Nuff said.
Sometimes it is hard to learn unless you actually use the equipment.
I keep nagging my brother in law to get a cordless hammer drill for those little jobs like putting a few screws in the cement to secure water lines. He said they were worthless and kept getting the Bosch, extension cord, and hunting for an outlet. I brought my cordless hammer drill to work one day and we had to drill a few holes. He went to get the Bosch. I pulled out my cordless and drilled the holes and had the screws in before he got back.
Being the guy that I am I let him set it all up before he saw that the water lines were all secured.
He bought a cordless hammer drill the next day.
11-15-2008, 05:55 PM
#9
Thanks Guys!! Man - - wish I would have known this earlier!!!
I rented a hammer-drill from Home Depot and it drilled right through the concrete easier than a wood drill going through wood!!
I could have saved my back and hernia a heck-of-a-lota strain if I'd have visited here first.
Thanks again everyone! Have a great Thanksgiving.
11-16-2008, 11:22 AM
#10
"Sometimes it is hard to learn unless you actually use the equipment."
Twenty years supervisor with college degree ought to know. But, I know what you mean.
MG,
I am hoping a good deal will come out during the shopping season on a cordless hammer drill. My use would be similar to the one you described. In other words, a few holes at a time, not an all day project. Which is why I have corded and cordless tools in most other categories. About how many holes can you get on a battery with hammer mode compared to similar sized holes normal drilling? I know thats a little stretch, but since you have one already, just thought I'd ask.
Now, if I can convince you know who to get the DeWalt hammer drill/ impact driver combo for twenty ? dollars more than the regular (18v) drill that needs replacing..... Promo deal at HD.
11-16-2008, 12:01 PM
#11
MG,
I get about half the time per charge drilling concrete. Mostly because it just takes longer especially if you hit a rock. I don't use it for anything big like 1/2" and 6 inch holes. Just small holes for doing Tapcons that are up to 2" or so.
My neighbor needed his shed secured to the concrete. It's not a big shed just for his lawnmower and a few tools. I got about 10 3 1/2" Tapcons in about 30 minutes on one charge. The holes were only 2" as the rest was in the sill plate.
Just made a call to HD and they will be putting the DeWalt cordless hammer drill on sale just for you for $50 and there is a $100 rebate....
11-16-2008, 04:57 PM
#12
In the days of yore, when hammer drills were a very expensive proposition, I had to do with my 3/8" Black and Decker.
I found that carballoy drill bits cut better if they are sharpened before being used for the first time.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
