Best Concrete Fastener - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-05-2009, 11:13 PM   #1
Rewards Points: 260
Best concrete fastener
What is the best concrete fastener? I'm planning on installing some objects on concrete walls. Are Tapcons best or are plastic anchors better?
bluefitness is offline   Reply With Quote
Old 07-05-2009, 11:52 PM   #2
Journeyman Wireman
I use plastic. But for very light applications. A better choice is something we call acorn anchors. Has a nut and washer on a threaded end and a bell end that wedges in the concrete when tightened.
jbberns is offline   Reply With Quote
Old 07-06-2009, 02:27 AM   #3
Rewards Points: 160
Depends how much weight you're hanging. Tapcons work great for a lot of purposes and are really fast to install. Buy the ones with a hex nut, not the Philips head.
philS is offline   Reply With Quote
Old 07-06-2009, 03:11 PM   #4
Rewards Points: 260
What is best to anchor large TV mounts (50in LCD)?
Old 07-06-2009, 10:55 PM   #5
Journeyman Wireman
In concrete I wouldn't trust tapcons for that expensive of a tv. I'd go with a wedge anchor or drop in is probally the strongest
Old 07-07-2009, 03:00 PM   #6
Weekend Builder
Crackers's Avatar
Tapcons are rated by weight (even the small ones can hold the TV weight, especially if you use many). TVs are static (do not move), so they are easier to hang than something that constantly changes weight (like a clothes line etc).
Drill slowly with correct size bit.
Crackers is offline   Reply With Quote
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 07:25 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
Help!: 4" concrete over 2' dirt over 7/8 wood planking! agent99 Flooring 4 04-28-2009 09:21 AM
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 10:38 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 02:32 PM
