? Best Cement/adhesive For Under Water? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-26-2010, 05:09 PM   #1
JPM
Bill Traver
Rewards Points: 101
? Best cement/adhesive for under water?
Looking for recommendations for the best cement/adhesive for tile on the side of pools. I have been using what the pool store has but it does not seem to hold well ..... I get maybe two years before the tile falls off.
Note: I do clean well before applying and I ensure that the water does not rise and freeze at this level during winter.
Any suggestions would be greatly appreciated.
Bill
JPM is offline   Reply With Quote
Old 09-26-2010, 08:21 PM   #2
Rewards Points: 4,732
bill, you won't get any decent performance til the prep's done right,,, you need to clean off back to the plaster coat or even thru it to the conc,,, same w/the tile - we use a 4" grinder & .110 diamond blade to scuff off the backsides,,, then try your underwater patch plaster again.
Old 09-26-2010, 08:55 PM   #3
Try full out epoxy grout and mortar.
wnabcptrNH is offline   Reply With Quote
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
Well Water snuggles2010 Plumbing 3 04-13-2010 01:36 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
