Old 08-05-2011, 11:21 AM   #1
Best adheasive for foam board to concrete
Last time I put foam board onto concrete block it was a pain! it took a long while for the glue to get a good grip on it and some places it didn't even grip.. used PL brand adheasive last time, said it was good for foam board...
I'm about to do this again... was wondering what you guys think is the best adheasive to use? I was walking through lowes last week and ran across this
http://www.lowes.com/pd_147975-970-8...0051&langId=-1
not sure if that is any good or not?
what would you recommend? I need something that dries tight, relatively fast and works good with foam board (XPS) to concrete block
thanks!
BlueBSH is offline   Reply With Quote
Old 08-05-2011, 04:06 PM   #2
no good suggestions? was hopping to start this tonight if someone had a better suggestion on what to use or just go with the same old PL brand
High Rise Building methods - US versus Oz - Steel versus Concrete Jado Off Topic 17 09-15-2011 09:47 PM
furring strips or 2x4s against concrete basement wall? denemante Building & Construction 15 01-28-2011 04:49 PM
Concrete Contractor and Masonry Contractor made a huge mistake homeowner12 Building & Construction 19 07-07-2010 10:37 PM
Crumbling Front Porch - Part 2 - The Repair jerseyguy1996 General Discussion 9 04-11-2010 07:11 AM
how to fill the gaps between concrete blocks? micapavlov Building & Construction 4 01-03-2010 05:53 PM
