Best adheasive for foam board to concrete
Last time I put foam board onto concrete block it was a pain! it took a long while for the glue to get a good grip on it and some places it didn't even grip.. used PL brand adheasive last time, said it was good for foam board...
I'm about to do this again... was wondering what you guys think is the best adheasive to use? I was walking through lowes last week and ran across this http://www.lowes.com/pd_147975-970-8...0051&langId=-1 not sure if that is any good or not? what would you recommend? I need something that dries tight, relatively fast and works good with foam board (XPS) to concrete block thanks! |
no good suggestions? was hopping to start this tonight if someone had a better suggestion on what to use or just go with the same old PL brand
| All times are GMT -4. The time now is 12:53 AM. |
