Old 06-29-2011, 07:33 AM   #1
Bending air ducts?
I am in the planning stages of finishing my basement and had a question regarding the flexible air ducts. I was wondering how much I might be able to bend the ducts in order to conserve some ceiling height (without restricting to much air flow)...or if there are any other possibilities. I would like to be able to frame out (ie. lower ceiling) as little as possible. Either way it won't be so bad. The lowest point would be about 7.5ft, its just that it is about 9.5-10 ft to the joists (which would really make the space feel bigger).
Bahuffma is offline   Reply With Quote
Old 06-29-2011, 07:47 AM   #2
Bending air ducts?
Here is a pic..
DIY relocation of HVAC ducts cbrc5eric HVAC 6 05-26-2011 09:29 PM
Can you glue to HVAC Ducts tro0925 HVAC 3 03-24-2011 04:31 PM
Asbestos on ducts and duct supply boots DanGauer HVAC 4 08-31-2010 08:09 AM
Replacing Ducts kuwdjones HVAC 4 01-09-2010 05:01 PM
Using PVC ducts instead of standard ducts robertmazzo HVAC 3 10-05-2006 05:26 PM
