Beginning To Plan Finishing Basement - Insulation Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-23-2009, 06:38 PM   #1
Beginning to plan finishing basement - insulation question
Hello,
I am planning to finish our basement over the summer in my spare time and would like some advice along the way.
My first question is about insulation. The basement is a poured foundation and mostly below ground level. Currently, the top half of the basement walls have 1 inch of a foil-faced insulation and the bottom half is just the concrete wall. I have been reading and reading, but I can't seem to find an definitive answer on whether I should insulate further with rigid foam. I plan on constructing 2x4 walls an inch or so away from the insulated wall. Would it be best to do nothing and frame as is, finish the bottom half of the wall with rigid foam, or do the whole wall over with rigid foam?
I am in Southern Ohio if that factors in. It can get down to zero degrees F here, but very very rarely.
Thanks for your help!
-Tim
ternstes is offline   Reply With Quote
Old 04-23-2009, 09:41 PM   #2
"yeah...we do that!!!"
i just did a job like that, i like running the insulation from floor to ceiling or at least the height of the foam board
do you have a french drain? that would also allow any sort of water or moisture to stay behind the foam board and be directed straight down into the french drain
that is usually the only insulation that i use in a basement. no batt insulation. that's me
also it keeps all your wall framing from touching the masonry the framing itself up tight to the foam board will hold up the boards
KOHNSTRUCTION is offline   Reply With Quote
Old 04-24-2009, 05:11 AM   #3
We have a sump pump. So, can I leave the top half with the foil insulation and do the bottom half with rigid foam and tape the joint between the two?
Old 04-24-2009, 11:27 PM   #4
If your going to frame the whole thing you may as well insulate with some R-12 fibreglass or Roxul (if in or close to Canada). The 1" foil faces is r-5 max and if you live in a area with cold winters you'll want to go with R-12.
joel v. is offline   Reply With Quote
Old 04-25-2009, 02:20 PM   #5
Registered User
Rewards Points: 5,216
Notice the references as you read:
Basement insulation / vapor barrier questions Be safe, G
Old 04-28-2009, 03:10 PM   #6
Is 1 inch of rigid foam on the walls going to provide enough insulation for southern Ohio climate?
Old 04-28-2009, 10:47 PM   #7
Registered User
Here is a great site: http://www.buildingscience.com/docum...gs?full_view=1
This one is similar, a lot of reading, but worthwhile! http://apps1.eere.energy.gov/consume.../mytopic=11810 Be safe, G
Tags
basement , insulation , remodeling
Question about Insulation of unheated basement ceiling dpdolstad Building & Construction 9 03-10-2009 01:49 PM
basement insulation and vapour barrier coolnes Remodeling 11 02-01-2009 09:56 AM
A few Q's on Finishing My Basement - Is there a FAQ on this? ossrocks Remodeling 6 01-07-2009 01:21 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
Basement framing insulation question Bcoleman6 Building & Construction 5 03-21-2008 07:37 PM
