Old 04-05-2012, 04:15 AM   #1
Been looking around at cost effective housing for property
I'm currently looking at a piece of land that has a house built in the 40s on it. The house is a tear down but the property is nice. Few acres, level etc. There is a shared well for this parcel and the neighboring house. There are power lines on the property as well as a pump house. I've been looking at cost effective housing for this property if I were to buy it. A traditionally built house over 1200 sq ft, I think is out of my price range. I have been looking at prefab houses a little but am open to any suggestions. I am thinking of something like 1200 sq ft or less, no garage, one level or two. I am also wondering about the foundation from the existing house. Could I use it to build on? The original house is 1100 sq ft. I don't have alot of experience with this kind of thing so I figure I'd leave it up to the experts here.
bikerider138 is offline   Reply With Quote
Old 04-05-2012, 07:51 AM   #2
MarginallyQualified
These questions can only be (fully) answered locally. Some are building department, some health department and some will require a structural engineer.
That said... making changes means meeting current codes. The existing water well (volume and set up) and the foundation are probably NOT going to meet current codes. You also don't mention the septic system...
From a financial standpoint, unless all these stars align in your favor,
the tear down is probably not going to be cost effective.
Sight unseen... investigate rehabbing the old house to make it habitable....
then either renting it out to finance the new build or adding on to some.
That term "investigate" means hiring an actual architect/engineer.
hth
Old 04-05-2012, 06:40 PM   #3
hth
There is no mention of the septic system by the seller. I think you hit the nail on the head, there could be hundreds of hang ups. I've heard that when building a house, plan to pay double the original quote by the time your finished. Thank you for your input, TarheelTerp.
Old 04-07-2012, 01:50 PM   #4
The prefab stuff they have now (a lot of startup companies out there) is pretty interesting. Here are a few links:
http://www.cabinfever.us.com/home.html - this one can go up to 800 sq. ft.
http://www.zookcabins.com/
juryduty is offline   Reply With Quote
Old 04-07-2012, 10:12 PM   #5
Thanks for links, I'll check them out
Old 04-08-2012, 10:38 PM   #6
long island, NY
also, investigate whether there's an ancient oil tank underground or other skeletons in the closet...
I love the idea of pre-fab homes. It definitely would be cost-effective, as long as local architects and engineers deem that they're up to code and would do well with the unique characteristics of the property.
My gut instinct is that you'll be pouring a new foundation... but that's also up to the local pro's.
diy'er on LI is offline   Reply With Quote
Old 04-09-2012, 04:31 PM   #7
Stuck in the 70's
Blondesense's Avatar
There is a shared well for this parcel and the neighboring house...
Our deed mentions a shared well (located on our neighbors property).
It is now considered by all to be our neighbor's well.
Our house has it's own well put in by the PO.
There is a history between our neighbors and the PO's over this situation that culminated in a nasty lawsuit.
The fact that the shared well is still in the deed concerns me.
Which will be more cost effective? manofmany Windows and Doors 2 03-13-2011 08:24 AM
ideas on water heaters comanche General Discussion 14 03-02-2011 11:15 PM
How much does a square foot of housing cost in Albuquerque, NM? spook4563 Building & Construction 2 02-28-2011 04:04 PM
Cost Plus Contract coachgns Building & Construction 9 02-10-2011 11:30 AM
What is the cost of adding brick ledge to new construction? toddtx Building & Construction 4 01-13-2011 07:04 AM
