Old 08-09-2012, 12:24 AM   #1
Bearing walls? Please help!
I would like to tear down the two walls shown in the picture below. The wall to the right enters into the kitchen. I'm removing them because I would like an open concept (living room, dining and kitchen all open. My question is it possible? Ive included pictures of what's below the walls in the basement. Please help!!!
I would like to remove both walls
Under wall with mirror
Under hallway wall
Jchermosillo is offline   Reply With Quote
Old 08-09-2012, 12:43 AM   #2
Going to need someone on site for this one. No one here can even guess how to do it without looking the whole house over.
Anything can be done if you have enough money.
mae-ling (08-09-2012)
Old 08-09-2012, 12:48 AM   #3
Thanks! So what kind of person should I call?
Old 08-09-2012, 12:54 AM   #4
An engineer would have to look it over design the layout and size the beams.
Then a contractor or in some cases you, can build it.
You will need permits for this.
Old 08-09-2012, 01:27 AM   #5
Thanks for your help!!!
Putting color onto white brick or textured walls (need color suggestions!) Eliana Interior Decorating 2 01-18-2012 08:27 PM
load bearing walls chaos1002 Building & Construction 8 01-15-2012 06:11 PM
Load Bearing Walls hwood71 Building & Construction 4 11-04-2011 03:43 PM
Removing load bearing walls Digle Carpentry 14 09-25-2011 10:36 AM
Load Bearing walls????? DoubleDD Building & Construction 1 11-23-2009 10:31 PM
