Old 09-04-2012, 08:54 PM   #1
bearing wall question
what is proper way to move doorway that is built through bering wall do i bloke it up first ,do i need supports , does it need cut or can i knock it out im only moving it 15ft
bullfloat11 is offline   Reply With Quote
Old 09-04-2012, 09:19 PM   #2
Is this just something like a 36" passage door in a roof framed wall?
If so there's no need to support the ceiling.
Leave the old header in place and just add a 2 X under it.
Make sure to build a header and use jacks in the new opening.
Old 09-04-2012, 09:51 PM   #3
AHH, SPANS!!!
use the opening size that the door is in now as the template for the new opening size or figure the rough opening to be 1" bigger than the outside of the door jamb measurement.
hand drive is offline   Reply With Quote
Old 09-05-2012, 11:16 AM   #4
really depends on what is above the wall.
Generally what joe has said is correct.
Although there are times when there can be a point load above, or heavy load.
mae-ling is offline   Reply With Quote
advice on expanding doorway in load bearing wall Jordan_Bailey84 Building & Construction 19 08-15-2011 10:33 AM
Load bearing wall question REXAMUS Building & Construction 14 08-01-2011 10:14 AM
load bearing wall question mudpaws Carpentry 3 06-24-2011 10:39 PM
Question about removing trim wall in foyer cary00silve Remodeling 1 02-02-2010 01:02 PM
Bearing wall, HELP me please jamiedolan Building & Construction 7 11-03-2008 12:33 PM
