Old 03-23-2009, 08:38 PM   #1
Bearing Wall - Finding a Contractor
Hello. First time poster. I've read as many posts as I can about removing a bearing wall. I am not going to do this myself, based on the advice I've read. However, I plan on finishing a basement, and here in the Atlanta area, builders frame supporting walls in basements in lieu of installing a beam. I want the basement opened up.
Here are the questions I've not seen answered.
1. How do I find a contractor who is experienced in solving this type of problem?
2. What are some questions I can ask to see if he is BS'ing me?
3. Any idea of the cost (ballpark.....$1000...$2000...$5000)? I do not have an unlimited budget, and the if the cost is too high to do this part, I might have to scrap it.
The wall is approximately 25 feet long, in the basement. It is a supporting wall. Above about 13 feet of it is the first floor, with no wall directly on it. Above the other 1/2 of the wall is a first floor wall, which is also, likely, supporting the second floor. The two pics are of the same wall.
I apologize if this is too vague. Any advice is appreciated.
Bearing Wall - Finding a Contractor-wall-1_edited-1.jpg   Bearing Wall - Finding a Contractor-wall-2_edited-1.jpg
imgetinold is offline   Reply With Quote
Old 03-23-2009, 10:21 PM   #2
Remodeling Contractor
If budget is a problem you may be disappointed. To remove this you need to make two temporary walls to hold it up while a new beam is installed. The only way to get a clear opening is to use a steel beam. Which means cutting a hole in the side of the house to slide the beam in place. Needs a full crew and will cost several thousand dollars. Building a wood beam will require posts and footings for these posts. Either way you are dealing with a lot of money.
how to-create doorway in load bearing wall Nikkil Building & Construction 4 05-14-2011 12:31 AM
Removing load bearing wall jjbarnes911 Remodeling 6 01-08-2009 10:32 PM
% total roof load on interior bearing wall? Grommet Building & Construction 1 03-29-2007 08:37 AM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 02:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
