Bearing Or Non-bearing, That Is The Question. (with Pictures) - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-18-2010, 07:22 PM   #16
Rewards Points: 87
I will go up there and take some measurements/ pictures. Was hoping that I didn't have to stay there for long ...
Stephen S. is offline   Reply With Quote
Old 03-18-2010, 11:26 PM   #17
Registered User
Rewards Points: 4,894
"Several problems...2x4'as as ceiling joists do not span very far..maybe 6'"------ depends on the species, Dave. 7'2" for SPF: http://www.colonie.org/forms/building/bdspanab.pdf
"If a home owner did the ceiling & the doorways they may not have thought they needed headers" ---- Looks professional to me.
Highly unlikely the ceiling joists all run perpendicular to the rafters. Only at the attic access, as I posted before. What is the span from the rafter to the next wall PAST the red wall?
Be safe, Gary
Old 03-19-2010, 02:17 AM   #18
Rewards Points: 87
---- I am pretty sure that those walls were here since the house was built in 1985 by the builder so professional job.
Interestingly, all the ceiling joists are made with 2x4's I am not sure if it's because of the truss design ? Any possibility that the 2x4's ceiling joists are holding up by the W-shape truss, thus wall A and B are not loaded?
Gary: "What is the span from the rafter to the next wall PAST the red wall?"
-- The 2x4's on top of red wall span 8 feet, then connect to another 2x4's with metal mesh and keep going to the other end of the wall and these 2x4's are connected to the W shape truss on top.
I tried to color coded the joist/truss in the pictures so the pictures can be connected.
Bearing or non-bearing, that is the question. (with pictures)-p1140597-large-medium-.jpg   Bearing or non-bearing, that is the question. (with pictures)-p1140612-large-medium-.jpg   Bearing or non-bearing, that is the question. (with pictures)-p1140605-large-medium-.jpg   Bearing or non-bearing, that is the question. (with pictures)-p1140615-large-medium-.jpg
Old 03-19-2010, 07:43 PM   #19
Registered User
A picture is worth a thousand words, you have a trussed roof system. Be sure to cut/pull any nails connecting the walls to the truss's bottom chord before demo. The angle/spacing of the strut members composing the different trusses is because of the hip roof on the end.
Be safe, Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
Stephen S. (03-19-2010)
Old 03-19-2010, 08:28 PM   #20
Rewards Points: 87
Thank you so much Gary and Dave! I should have taken "big" pictures from the beginning ... just focused on the walls I want to demo
A picture is worth a thousand words.
Supporting floor joists on non-load bearing wall? ct9359 Building & Construction 4 07-17-2009 01:59 PM
Running duct over bearing wall jhillman HVAC 10 03-23-2009 03:54 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
hrv question indep HVAC 3 07-17-2008 11:39 PM
Concrete slab question houdinihar Building & Construction 2 06-07-2006 09:04 AM
