Bearing On Concrete Block Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-27-2009, 06:53 PM   #1
Bearing on concrete block wall
Private home inspector goes in the crawl space, we did 8 in block foundation walls and left a pocket for a drop sill to sit in. Underneath the drop sill is a piece of treated 2*6 for a mudsill, and under that is conc brick. What is code for bearing that weight? Home inspector is saying that we don't meet code
Toolmaster is offline   Reply With Quote
Old 08-28-2009, 04:08 AM   #2
Remodeling Contractor
A steel lintel should be used. The deflection should match the block. A 2X6 on the flat will not do.
Old 08-28-2009, 07:11 AM   #3
Concrete & Masonry
Rewards Points: 568
If what your refering to is something along the lines of a beam pocket, then the only material that can (& should) be used to shim the beam is solid masonry or steel shims. I've seen many jobs tagged by inspectors because cedar shims, wood blocks, etc... were set under the beams temporarily, & the carpenters "forgot" to replace them. It's much easier to shim when setting the beam than to replace the shims AFTER the beam is loaded with weight.
jomama45 is offline   Reply With Quote
Can foam sealer be used to seal the spaces in concrete block? marksto Building & Construction 6 04-21-2008 07:48 AM
framing, expanding wall opening wall - load bearing? nave Remodeling 5 01-23-2008 03:44 PM
% total roof load on interior bearing wall? Grommet Building & Construction 1 03-29-2007 07:37 AM
Concrete Block Wall rag4rdd Building & Construction 2 02-14-2007 11:41 PM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 01:39 PM
