Beams That Span 14 Feet How Ar Can I Space Them? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-06-2010, 01:44 PM   #1
beams that span 14 feet how ar can I space them?
Hi everyone,
I am planning to build a shed roof with a post and beam look and was hoping to have to use either a 4x6x15 or 6x6x15 beam spaced 3 or 4 feet apart on center. is this possible and would these sort of beams work ok or would i need something else. in live in new england and occasionally have snow so i think i need to worry about snow load. this roof is simply to cover a concrete patio that we have now.
Extreme66 is offline   Reply With Quote
Old 04-06-2010, 05:30 PM   #2
jlhaslip's Avatar
Rewards Points: 1,572
lots of span calculators available on Google
they seem shallow to me.
and what are you planning for decking on top of that? Insulation?
any Timber framers in your area? http://www.northernlightstimberframi...preadsheet.htm
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 04-07-2010, 01:47 PM   #3
Technically, minimum code would still require you to use 6x6 rafters 36"oc. You'll still have 3/4" deflection under a decent snow load. Personally if it were mine, I would use 4x8 rafters if I wanted to use 36" spacing.
The bigger issue is what you're gonna use for decking. Make sure you use a decking that is rated for a 36" span. Also, make sure your beams supporting those rafters are stout enough.
Cache is offline   Reply With Quote
Old 04-10-2010, 05:23 PM   #4
It also depends on the modulus, E, for the wood you are using; 1 million PSI is about average.
Old 04-12-2010, 03:13 PM   #5
You are correct. I used 1.2 Million for my post above. We usually use SPF lumber around here.
Tags
beams , joists span , roof
Concrete piers in 55 gal drums support I beams DeanPk Building & Construction 13 07-05-2016 08:17 AM
Center bearing vs. Clear Span floors -- Span Tables WaldenL Building & Construction 2 02-24-2015 06:50 AM
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Crawl Space Questions (with pics) burnt03 Building & Construction 4 11-04-2009 06:44 PM
Structural integrity of fir 6x6 beams ashen Building & Construction 8 07-31-2008 06:31 PM
