Beams - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-15-2007, 07:18 AM   #1
beams
the main beam that supports the floor joist is moving from one end of the basement to the other the walls are move basement widows are cracking any suggetions as what might be causing this and how to fix
kwheaton is offline   Reply With Quote
Old 02-15-2007, 07:29 AM   #2
I wish i had an answer for you but i cant understand what that says or means. Try rewording it with some punctuation and ill try to help.
msi2980 is offline   Reply With Quote
Old 02-15-2007, 07:38 AM   #3
the beam in the basement that the floor joist rest on is moving.
Old 02-17-2007, 05:06 PM   #4
What do you mean when you say "moving from one end of the basement to the other"? Do you mean that the floor joist are sagging and the weight from the upper floors is causing your basement windows to crack?
mebsdad is offline   Reply With Quote
Old 02-17-2007, 05:14 PM   #5
concretemasonry's Avatar
Rewards Points: 2,578
beams
Hire a structural engineer to look at it before it gets worse, if possible.
concretemasonry is online now   Reply With Quote
Old 02-17-2007, 05:19 PM   #6
I agree with Concrete, if you have a situation where you have windows cracking, you need the input of an engineer. At the absolute minimum, contact your local building official/inspections department.
Old 02-18-2007, 07:55 PM   #7
Just a guess based on vague details.
The main beam running end to end may have been cut short to avoid contact with the foundation. Should have been secured with by a number of ways but may not have been. Have a Contractor or engineer have a look.
Rich
Remodeling is offline   Reply With Quote
Old 02-18-2007, 08:00 PM   #8
Licensed Remodeling GC
kevjob's Avatar
can you post a pic? Most likely the failed connection from post to beam or beam pocket is the culprit.
kevjob is offline   Reply With Quote
faux wood beams? zel Remodeling 11 07-07-2010 03:28 PM
"Wagging in" 2x8 beams for my deck? deckman Carpentry 5 08-08-2007 11:35 PM
where to get support beams elementx440 Building & Construction 5 03-21-2007 06:19 PM
Steel beams and Posts dhenrycpa Building & Construction 21 01-01-2007 07:52 PM
help with support beams on porch falcon802 Carpentry 3 06-24-2006 11:00 AM
