Beam Span When Laminated - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-04-2012, 09:11 PM   #1
beam span when laminated
Looking at wood beam span tables for a deck i can go roughly 14' between posts when the posts are 8' high and the deck is made up of 3-2x12 laminated together. Can anyone tell me how much further I can go between posts if I laminate in 2 pieces of 3/4 inch treated plywood between the 2x12?
billybarty is offline   Reply With Quote
Old 07-04-2012, 09:17 PM   #2
AHH, SPANS!!!
Rewards Points: 1,166
you would be better setting a quad instead of plywood in the beam, plywood has breaks every 8' so would lessen strength considerably at the breaks.
hand drive is offline   Reply With Quote
Old 07-04-2012, 09:25 PM   #3
I don't have any spans on tables I have found on the net for a 4x beam. I need to go 16' on one side of the center post and 23' on the other side. Will a 4x beam handle that?
Old 07-04-2012, 09:44 PM   #4
Rewards Points: 13,276
A 4 X beam will sag, twist and check.
Plywood would also rot with the end grains laft exposted between 2 X's.
Far better to just add more supports to shorten up the spans.
Old 07-04-2012, 09:53 PM   #5
robertcdf's Avatar
Go steel or a glulam beam
robertcdf is offline   Reply With Quote
Old 07-04-2012, 09:54 PM   #6
Framing Contractor
Have an architect or engineer spec a treated glulam.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 07-05-2012, 12:15 AM   #7
Rewards Points: 508
These links might be of use:
http://www.johnbridge.com/vbulletin/deflecto.pl
http://www.woodbywy.com/services/s_forte.aspx
http://www.hsh.k12.nf.ca/technology/...e_11/index.htm
You can use the Forte software (free from Weyerhaeuser) for more than just I-joists.
benjamincall is offline   Reply With Quote
Old 07-05-2012, 08:02 AM   #8
AHH, SPANS!!!
23' is a long way to span with regular 2x lumber. you would need an engineered beam for that span along with a qualified engineer to recommend the beam sizing. if possible, a post for each mid span from center looks like the way to go...
Span for 2x8 support beam TCS-Austin Building & Construction 7 10-25-2011 10:17 AM
How to repair main support beam Jerry48ece Building & Construction 0 01-08-2011 09:38 PM
Main Beam De-Laminating Bird Doo Head Building & Construction 6 12-09-2010 01:08 PM
Patio Roof Beam Span slakfu Building & Construction 4 06-03-2009 11:45 PM
laminated beam outside? rtoni Building & Construction 6 03-10-2009 07:35 PM
