Old 11-08-2009, 01:03 AM   #1
Default beam size&constrution 22x19 ceiling
hi need info i am attempting to remove an 16 foot load bearing partition wall inside a 22ftx19ft interior diameter room ceiling joists onlysupport drywall ceiling . joists run across 22ft width partition wall is 10ft from one wall(22ft width) and3ft in on each side (19ft width) joists have already been sistered up for strength (org joists old time full 2x6 . sistered with new2x6s) i have excellent structure at both end locations to support beam (foundation walls). do i need a parrallam style beam or can i bolt,screw&glue 3 or 4 2x10s or 2x12s together to span the19ft width . there is no roof load on the ceiling or above partition inside attic thanks for reading this
scotty113 is offline   Reply With Quote
Old 11-08-2009, 05:58 AM   #2
General Contractor
I've never seen a built up beam span that far, so I would not attempt it. You have to calculate the load to determine what size beam you need. If you're not comfortable with that, then you should hire an engineer to do it for you. Anyway, if you want to use a PSL, here are some instructions on how to size them properly http://www.ilevel.com/literature/COM-4000.pdf
KennMacMoragh is offline   Reply With Quote
Old 11-08-2009, 11:00 AM   #3
Extreme DIY Homeowner
Scuba_Dave's Avatar
To span 22' I had to go with 3x 16" LVL's - supporting room above & roof loads
You need to have the size engineered by a lumber yard possibly or an engineer
There is no guessing on a beam this big
DIY Chatroom Moderator
Not a Pro or for hire, I have enough to do on my own house, Just Look !!
http://www.diychatroom.com/f49/house-renovation-ongoing-37438/
More On This Topic
Ceilings in an older house can be unsightly. A relatively inexpensive way to solve the problem is to install ceiling tile. While you can attach ceiling tile directly to the ceiling with glue, it's easier to install furring strips and attach the ceiling... Read More »
Hi, this is Jon and in this clip we will be installing our fixture box. Now, with the can light that we pulled out, the diameter is about six inches. However, the diameter for our mounting plate is only about four inches. Now, because our opening is so... Read More »
My name is Brent Shelly with Expert Village and we are talking about lighting design today. When lighting wall art, the best source to use is a MR16. There are twenty different beam spreads and wattages that you can choose from using the MR16. It is also... Read More »
Remodeling, whether it is in the garage or in the house is a huge undertaking. One of the easiest projects is building a non-bearing interior wall. The tools are basic, as are the needed carpentry skills. The condition of the floor and ceiling will... Read More »
If you are at a loss as to what to do with your keepsakes, handed down furniture, year books, children’s toys or holiday ornaments, you should look up and consider your attic. Homes used to be made with stairs that went to the attic. Here children... Read More »
Ceiling joists support beam ptcamaro Building & Construction 3 06-17-2009 12:14 PM
Mounting Ceiling Fan to Exposed Beam zero1niner Electrical 7 05-05-2009 01:41 PM
Remove Load Bearing Wall Beneath Hanging Beam cnaildrivenail Remodeling 0 04-29-2008 01:06 PM
Vaulted Ceiling, faux wood beam, ceiling fan? zel Electrical 10 10-01-2007 03:47 PM
Ceiling Joist Beam Construction? Stargazer Building & Construction 1 08-27-2007 12:50 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
