Old 03-10-2012, 11:09 AM   #1
beam size
i want to put sunroom on back of house 10 feet by 30 feet with 3/10 shed roof style. my concrete patio is only 5 inches thick so need beam to span 30 feet cause can't do supports in middle. i have garage wall at one end for support and can dig support for other end.
What size and what kind of beam do i need?
thanks
ratboy857 is offline   Reply With Quote
Old 03-10-2012, 11:16 AM   #2
Framing Contractor
beam size
Why not? You cut a section out and put a footing in. This is done a every day.
thanks
If you insist on going with a 30' beam, no one here on the internet can size that for you. If someone does and you listen that wouldn't be smart and it would be dangerous.You need to have it sized by an architect or engineer.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 03-10-2012, 11:25 AM   #3
Framing Contractor
beam size
I was going to mention the same thing about cutting the concrete Joe. I think he wants the beam to span 30' rather than 20'. Good luck with that long span.
sixeightten is offline   Reply With Quote
Old 03-10-2012, 11:27 AM   #4
Framing Contractor
beam size
I meant 30' ...typo.. Thanks for picking that up. Didn't have my coffee yet...;-)
Joe Carola
Old 03-10-2012, 11:28 AM   #5
beam size
It is an exposed ag concrete so it would never match. I figured I would need an engineer but thanks anyways
Old 03-10-2012, 11:30 AM   #6
Framing Contractor
beam size
Can you build up the footing a little higher than the patio and wrap it with stone or something else that's nice looking and set the post on top of that?
Joe Carola
help with main beam silky Building & Construction 12 07-08-2011 11:37 AM
what size beam for jacking up floor joists ponch37300 Building & Construction 19 02-07-2010 10:13 AM
replacing beam in basement bpahwa Building & Construction 4 01-12-2009 08:12 PM
recessing a beam needa Building & Construction 12 12-26-2008 11:29 AM
Beam Size sevver Carpentry 15 04-30-2008 01:51 PM
