Beam Size - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-27-2011, 06:56 PM   #1
Rewards Points: 14
Beam size
Hi I am removing a wall and want to replace it with a glue lam, or micro lam beam just wondering what size to use I want to create a open look so I would like to go wider rather then deeper just to give a little info the span is about 13 feet.The attic is above it and the ceiling joist do brake on it. There is also the heat/air conditioner handler that sits on it. The roof is about a 5/12 so I thought that some day it may be used for storage. I do have some random plywood up there now and with the handler I will not be able to cut the ceiling joist back and hang the like I wanted to. Thanks for any help.
flynavy is offline   Reply With Quote
Sagging Ceiling Joists - Adding Beam In Attic DoItMyselfToo Building & Construction 11 11-30-2010 06:20 PM
what size beam for jacking up floor joists ponch37300 Building & Construction 19 02-07-2010 09:13 AM
Floor beam strengthing A1972 Building & Construction 1 01-18-2010 06:33 PM
recessing a beam needa Building & Construction 12 12-26-2008 10:29 AM
Beam Size sevver Carpentry 15 04-30-2008 12:51 PM
