Beam Replacement In Basement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-25-2011, 08:49 PM   #1
Beam Replacement in Basement
I am currently looking at replacing a beam in my basement. Currently it looks like there are 3 2x8's tied together running under the floor joists spanning a 20x20' floor. There are 2 columns supporting the floor beam. I was looking at sizing an LVL beam for this so I can get rid of the support columns. This is not a load bearing beam, just supporting the floor above. I am concerned about ceiling height at the beam if I get an LVL. Currently the floor joists (2x 10') are tied together at the ends and are on top of the support beam. Is it possible to cut the joists then attach them to the LVL using joist hangers? I attached some pictures which may help.
dbennett78 is offline   Reply With Quote
Old 04-25-2011, 08:52 PM   #2
Framing Contractor
Rewards Points: 118
20' is a long span for an lvl. It will be a pretty big one. Yes, usually you can hang the joists from the beam. But I bet when you size it, a lot of beam will still hang out of the bottom.
sixeightten is offline   Reply With Quote
Old 04-25-2011, 08:58 PM   #3
Understood that they are pretty big, but is it possible to cut the current joists and rehang onto the beam? That way I could gain the space currently occupied by the joists. Would a steel I-beam occupy less space?
Old 04-25-2011, 09:02 PM   #4
Framing Contractor
Rewards Points: 118
Yes to both questions. Lets say that a 16" 3 ply micro will work (Not saying it will!) You could support the joists on both sides of the cut by building temporary support walls near the cut out. The micro could be slid up to the floor which would leave 7 or 8 inches hanging below. The joists can also be hung from a steel beam. An engineer needs to be consulted to determine which beam works best. Good luck.
Sagging Ceiling Joists - Adding Beam In Attic DoItMyselfToo Building & Construction 11 11-30-2010 06:20 PM
Basement beam concern Rife Building & Construction 1 07-11-2010 12:16 PM
replacement basement window - how to measure? qchawkfan General DIY Discussions 9 01-20-2010 07:42 PM
Concrete Basement Beam jrepp44 Building & Construction 1 01-06-2010 01:39 PM
Basement Window Replacement mebsdad Building & Construction 2 02-19-2007 08:10 AM
