Beam Membrane For Deck - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-22-2008, 12:04 PM   #1
Weekend Butcher
beam membrane for deck
Hi
Im in the process of building a deck and was wondering if it is nessasary/a good idea to cover the top of the beams with a weatherproof membrane of some sort. The decking will be cedar and the framing ACQ so im guessing water will sit on the beams.
thx
drewid153 is offline   Reply With Quote
Old 08-22-2008, 03:31 PM   #2
Registered User
Termite's Avatar
If your beams are ACQ they're treated to take the water. There's nothing wrong with installing a strip of flashing or ice/water shield on top of them, but with treated wood it is an unnecessary step.
Old 08-22-2008, 06:31 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Not necessary on the joists.
Tho, we do install a membrane strip on joists that are doubled (New England). The reason we do that, is to keep water out, that can freeze and expand, and pull and warp the two or more boards from eachother. This is not required, just a little over kill we like to do...
- Build Well -
Old 08-23-2008, 07:34 AM   #4
BUILDER / REMODELING CONT
buletbob's Avatar
Nice Tip.
Old 08-23-2008, 08:52 AM   #5
Registered User
Termite's Avatar
Originally Posted by buletbob View Post
Nice Tip.
Sure is!
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Q:Temp support to replace beam and posts on deck dougq Building & Construction 10 09-02-2008 05:24 PM
Beam Replacement? Steve Dailey Carpentry 5 05-19-2008 09:46 PM
