Beam Intersection - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-14-2009, 05:01 PM   #1
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,364
Beam intersection
I'll need to hang a beam on another beam as point load.
See Pic:
Beam A is installed. It's a built 5.25 x 11 7/8.
Beam B is new, built 3.5 x 14
Beam B intersects A at a higher point so I need to figure out how to attach these together.
My idea is to use blocking (C - 3.5 x 6.75 LVL) to attach the hanger to and then strap the block to beam A. Is there a better way to do this or does this seem like a decent idea?
TIA
I tear things down and build them up.
Clutchcargo is online now   Reply With Quote
Old 12-14-2009, 05:06 PM   #2
I would think Simpson strongties would make a single hanger without the buildup on the existing beam and you could add lags from back side to help eliminate roll. if I understand your drawing correctly. you could also notch b to add additional support
Old 12-14-2009, 05:10 PM   #3
I have gas!
I thought so too. I tried to order this hanger so that the flange is lower but it's not offered that way.
By using blocking as depicted, it would spread the point load out, which I like.
Here's a bad picture of the wall I'm removing.
Old 12-14-2009, 05:18 PM   #4
Pro
go to a local iron-worker and have them make up a bridle hanger, with a flap set to the height you want, and the sides to go full height of the taller beam.
i typically take this route on funky intersections with heavy loading.
ClemS is offline   Reply With Quote
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Crawl Space Beam and Joist Support Questions Fire4Effect Building & Construction 5 06-28-2009 01:07 PM
Q:Temp support to replace beam and posts on deck dougq Building & Construction 10 09-02-2008 04:24 PM
Beam Replacement? Steve Dailey Carpentry 5 05-19-2008 08:46 PM
