Beam Connection? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-20-2011, 11:14 PM   #1
Beam connection?
It's a three level deck ,ledgered to a hotel.third floor balcony is closer to the building than first and second,that makes me triple the 2x10 joist under posts supporting third floor balcony.how do I connect those beams to front "band " beam if my 6x6 posts are in the way?can't notch it anymore ,because it's notched on outside for a double 2x10 and I can't move them,because columns have to line up.any ideas?
Fachovec is offline   Reply With Quote
Old 03-21-2011, 12:19 AM   #2
Registered User
Rewards Points: 5,212
Should be called out on the plans the Building Department permitted...
Gary
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
deck - beam to post connection (??) brocasArea001 Carpentry 21 05-11-2011 09:39 PM
How to repair main support beam Jerry48ece Building & Construction 0 01-08-2011 09:38 PM
Main Beam De-Laminating Bird Doo Head Building & Construction 6 12-09-2010 01:08 PM
Deck Beam connection to Post? CNJHomeowner Building & Construction 7 08-08-2008 07:14 AM
