Old 03-20-2009, 10:22 AM   #1
Beam base support footing, how deep?
Hi all,
I need to install a set of beam supports under the house in order to reinforce a beam that was cut in order to make way for plumbing. I did not do that job, it was the way I purchased the house. I know I have to make a footing for each column, how deep are these cement footings recomended to be?.
gante is offline   Reply With Quote
Old 03-20-2009, 10:38 AM   #2
The footing size is based on the loads on the column. How much weight will bear on the supports?
Ron
Old 03-20-2009, 11:13 AM   #3
Moderator
Termite's Avatar
They start at 8" and go thicker from there. It totally depends on the imposed loads, the widths of the pad and the soil's bearing capacity.
Old 03-20-2009, 04:45 PM   #4
Ron
I did not give this much thought but it should not be much weight since it currently has no supports at all under the beam and still standing and no signs of bowing yet. I just want to install two of these columns to reinforce a beam that was cutted to make way for the plumbing. I am doing this as a precaution.
Old 03-21-2009, 12:11 AM   #5
It might help to post a picture.
Ron
How to add another support beam under floor joists LOStouten Carpentry 3 11-13-2008 11:55 PM
Q:Temp support to replace beam and posts on deck dougq Building & Construction 10 09-02-2008 05:24 PM
Floor Support Beam SlipperyPete Building & Construction 3 12-04-2006 06:55 AM
drilling a support beam sdmotor Building & Construction 1 07-12-2005 11:51 PM
