Old 06-05-2011, 09:33 AM   #1
Beadboard roofing material
Wondering if it is acceptable to use 3/4" beadboad plywood on my porch roof so that I get the beadboard look underneath, but have exposed beams. I would put shingles on top of the 3/4" beadboard plywood. Is this something that people do? Is the 3/4" beadboard plywood durable enough for roofing applications? Thanks.
crhage is offline   Reply With Quote
Old 06-05-2011, 10:04 AM   #2
Tom Struble's Avatar
you can do that,but you need too probably hand nail the roofing on with 3/4'' roofers,the smallest gun nail i believe is 1'' and will penetrate through the beadboard sheathing
Tom Struble is offline   Reply With Quote
Old 06-05-2011, 10:37 AM   #3
What I might do is cover the 3/4" beadboard ply with 1/4" or 11/32" OSB and then use 1" or 7/8" roofing nails. Thoughts?
Old 06-05-2011, 12:53 PM   #4
even better,use the osb over it
Old 06-05-2011, 01:05 PM   #5
got an even better idea...less expensive. Use 1/4" beadboard ply first and cover that with 3/4" OSB. Save some money and get the same effect.
Old 06-05-2011, 02:55 PM   #6
you win
Old 06-06-2011, 01:19 AM   #7
plywood, not osb. any leaks, and the osb may be toast; at best, it will swell and get soft.
Old 06-06-2011, 01:38 AM   #8
osb is fine
Old 06-06-2011, 02:14 AM   #9
dry, yes. wet, no. i don't like how it does not hold screws well, either. maybe just my bad luck.
Old 06-06-2011, 10:27 AM   #10
SteelToes's Avatar
Originally Posted by tomstruble View Post
osb is fine
It should be renamed into JOSB = JOBS
jOb Security Board.
SteelToes is offline   Reply With Quote
Old 06-06-2011, 09:51 PM   #11
yea like that wouldn't happen to any kind of sheathing...give me a break
i have never seen osb turn to mush from intermitant wetting,but i have seen plywood delaminate
Old 06-07-2011, 08:22 PM   #12
place down your boards then sheet the roof with plywood, chalk your trusses so you dont nail through into your fancy beadboard . depending on anything less then a 4-12 youll need to use ice and water underlay. but thats your discretion.
Serious Roofer is offline   Reply With Quote
Old 06-09-2011, 07:18 PM   #13
Thanks folks. Great discussion. I think I'm on track with this one.
roofing material suggestions - flat commercial roof mherder79 Roofing 3 05-25-2011 10:02 AM
Roll Roofing Edge Leak toolboxone Roofing 5 10-07-2009 07:09 AM
Roofing material for less than 3:12 pitch seth Roofing 5 07-21-2009 09:41 AM
Roll roofing material RedDawg454 Roofing 8 05-03-2007 07:52 AM
What roofing material is right for me? Grumpy Roofing 0 07-07-2004 08:41 PM
