Beadboard Ceiling - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-16-2012, 05:02 PM   #1
Beadboard ceiling
We would like to replace the 1960's ceiling tiles in our home with the beadboard panels or strips found in home improvement stores. If we remove the ceiling and install the panels or strips (which are very thin), will we lose any of the insulating factor that the tiles had? We have 10 to 12 inches of sprayed in insulation on top of the insulation sheeting that was installed originally.
Last edited by brook_1975; 06-16-2012 at 05:03 PM. Reason: quotation marks changes to symbols
brook_1975 is offline   Reply With Quote
Old 06-16-2012, 07:55 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 582
Not enough that you will notice.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 06-16-2012, 08:01 PM   #3
Rewards Points: 14,026
Go to a real lumber yard and look into real wood, 3/8" thick T & G in the longest length you can get.
It needs to be prefinished before it's install.
Old 06-17-2012, 09:44 AM   #4
AHH, SPANS!!!
Rewards Points: 1,166
if you pull the 1960s ceiling panels down will the new insulation fall out of the ceiling? just wondering if that would be your first obstacle. by, insulation sheeting do you mean the aluminum foil stuff with the re enforcement in it?
hand drive is offline   Reply With Quote
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 08:26 AM
Ceiling issue wooten General DIY Discussions 5 06-06-2011 07:20 PM
Creating a vaulted ceiling for patio tcaesar1 Building & Construction 1 04-26-2011 10:30 PM
Beadboard ceiling bigboyjoel Carpentry 32 04-14-2010 11:13 PM
beadboard ceiling in kitchen bernice General DIY Discussions 2 02-23-2008 09:34 PM
