Battens For Board & Batten Siding? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-04-2011, 07:08 PM   #1
Battens for board & batten siding?
I have a 50 yr old house w/board & batten siding. It has a substantial carport w/the same siding. I want to put up a 3rd wall on the carport and roughly match the siding. The original battens are 5/8" thick and 2 3/4" wide. The only lumber I can find that thickness are short specialty boards for small projects - they are very expenive. Any idea where I could find equivalent battens or just 1/2" thick lumber that I could rip to width? The big box stores are no help.
Thanks!
Junestan is offline   Reply With Quote
Old 07-04-2011, 07:21 PM   #2
kwikfishron's Avatar
Rewards Points: 86
1x6 and a table saw, make your own.
kwikfishron is offline   Reply With Quote
Old 07-04-2011, 07:25 PM   #3
DIY staff
Rewards Points: 7,174
If you need a lot--a surface planer might be worth the purchase---otherwise,Kwickfishron has the cheapest suggestion-- be careful and rip wider boards to width--then rip again to get the thickness.
Old 07-04-2011, 07:27 PM   #4
I know I can rip the 6" wide down to 3" but will I be able to cut the thickness in half too? I have a more experienced person helping - maybe w/a better quality table saw we could do this?
Thanks!
Old 07-04-2011, 07:30 PM   #5
I only need about 26. Will give the ripping a try. Thanks much!
Old 07-04-2011, 07:41 PM   #6
Rewards Points: 86
Just rip a 1x6 (¾” thick) in half and be done with it. You will never know that on the wall around the corner the battens are 1/8” thicker.
The Following User Says Thank You to kwikfishron For This Useful Post:
Junestan (07-04-2011)
Old 07-04-2011, 07:44 PM   #7
Will do - thanks much!
Old 07-04-2011, 08:02 PM   #8
Are the doug fir 1x3 boards I see on the Lowes website stainable? http://www.lowes.com/pd_6747-99999-1...C1&facetInfo=1 x 3 I've bought bare wood before that took paint but not stain. How does one know?
Old 07-04-2011, 08:09 PM   #9
DIY staff
If it rains where you live---I suggest cedar----the doug fir will work if you prime and paint the back side before installing.
Old 07-04-2011, 08:14 PM   #10
Rewards Points: 86
Yes DF is stainable. What’s the species of the original battens? I’d be trying to match that first. As Mike said I'd use cedar over DF.
Old 07-04-2011, 08:18 PM   #11
I don't know what the original battens are. The area that's not stained is reddish brown - cedar? Since it's only the garage I'm not being too picky, just want it to match the basic look of the house.
Old 07-04-2011, 09:03 PM   #12
Registered User
Rewards Points: 4,912
It was probably "green" rough cut cedar, hence 2-3/4" wide dried down from wet, not surfaced at the mill for standard size, 2-1/2". Do you live near any cedar farms or mills?
Gary
Old 07-04-2011, 09:18 PM   #13
I think it's probably redwood - I'm in No CA and there's plenty of it here. I can see that I need to do more homework since if I don't get the right wood/stain combo it's going to look crummy. I was going to get my stuff at a big box store next time I was in the "big city" but now I think I'll stick to our little local lumber yard and pick their brains, try some stains on different stuff, and see what works.
The Following 2 Users Say Thank You to Junestan For This Useful Post:
Gary in WA (07-04-2011), kwikfishron (07-04-2011)
Old 07-04-2011, 09:43 PM   #14
Rewards Points: 86
Post a picture of what you’re trying to match.
How to attach a photo to a post
Old 07-07-2011, 08:58 PM   #15
Thanks!!
Thanks everyone for your great help. Sorry for the late reply - I had to deal w/a family emergency for several days. Everything OK now. I got some sample rough-cut plywood siding and a 1x3 board. Spent a lot of time trying and comparing stains (oh that poor young man at Ace!) and I think I've finally got what will work. I think this will be a pretty close match to the existing siding and fits my meager budget.
I've never gotten so much good advice so fast on a forum. Thanks again!
Tags
batten , board , siding
Caulk between boards (board and batten siding) Briandl Building & Construction 10 09-11-2011 12:07 AM
Board and Batten wood siding Knucklez Building & Construction 39 11-07-2008 11:38 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
