Bathtub Vapor Barrier Detail - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-21-2009, 02:55 PM   #1
Bathtub vapor barrier detail
Ok, ok, I've been all over the web, and read all kinds of stuff on vapor barriers for showers and tubs. I'm going to use 4 or 6 mil plastic attached to the studs and durarock on top of that. My question is... at the bottom where I lap the plastic over the edge of the tub (so water caught by the barrier will go back into the tub). I will then tile over the durarock starting a quarter inch above the tub. When I'm done I'll caulk the quarter inch gap between the tub and the tile, also sealing the vapor barrier. So how is water going to get back to the wet side of the tub? The caulk bead needed to keep water from getting from the wet side to the wall will also stop any water stopped by the vapor barrier from draining out from behind the tile. Is there some way to have some weep holes or is this not a problem?
Schwarzaroo is offline   Reply With Quote
Old 01-21-2009, 03:06 PM   #2
K&B Remodeler/Tile Guy
angus242's Avatar
My suggestion is to WATERPROOF the surround area before tiling.
Kerdi is a waterproof membrane that installs over the Durock and then you tile directly over. There's no need to use a vapor barrier behind the Durock.
http://www.schluter.com/6436.aspx
You can find a video about installing Kerdi in a shower so you can see how it's done. You can find the Kerdi instructions and it details installing over a tub deck.
Look at my albums to see a bathroom in progress that has Kerdi.
Angus
My Albums
angus242 is offline   Reply With Quote
Old 01-21-2009, 03:20 PM   #3
Registered User
Termite's Avatar
The poly vapor barrier isn't a great way of doing things.
Angus' suggestion is the top notch way to do it, but can set you back $200+. It is the best system available.
If budget is a concern, a good compromise is a product that you "paint" on the exposed face of the backerboard just before you tile. It is called RedGuard, and is available at the box stores. That will keep water from ever permeating your backerboard, which is the best scenario.
Old 01-21-2009, 04:50 PM   #4
I've heard it's also good to fill your tub before you caulk
Chemist1961 is offline   Reply With Quote
Old 01-21-2009, 05:44 PM   #5
I never used that Kerdi before. Good tips. Thanks for the posts
II Weeks is offline   Reply With Quote
Old 01-21-2009, 10:38 PM   #6
Registered User
Termite's Avatar
Trust me, Kerdi is incredible. And, it is stupid-simple. Good vids of it on youtube.
Floor load w/ bathtub DSKUP Building & Construction 5 12-30-2008 10:07 AM
need to convert a bathtub into a shower q5485 Plumbing 9 11-30-2008 09:39 PM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 10:42 AM
Refinishing bathtub or installing new one? gante General DIY Discussions 7 06-23-2008 02:54 PM
Help with ID'ing bathtub sound... DIY-Gal Plumbing 12 02-10-2007 05:45 AM
