Old 02-02-2011, 05:58 PM   #1
Bathtub surround.
I have a bath surround that includes the tub. It looks like the wall sourround is seperate because I can see the seams around the top of the tub. Can I remove only the wall surround and install tile and keep the remaining tub surround ?
GWEN BENYO is offline   Reply With Quote
Old 02-02-2011, 06:24 PM   #2
Persona Non Grata
VIPlumber's Avatar
Bathtub surround.
Hi Gwen,
Could you post a pic so we have an idea of what kind of surround you have?
VIPlumber is offline   Reply With Quote
Old 02-02-2011, 07:30 PM   #3
Tileguy
Bud Cline's Avatar
Bathtub surround.
Not making much sense to me!
Old 02-02-2011, 07:35 PM   #4
Bathtub surround.
I have tried, but for some reason I am unable to attach the pictures. So iI have given more info. Maybe it will help. I think the wall surround is in three pieces(seperate back, side and front panels) and is only attached at the egdes. I think this because I can push in the middle of the wall surround and it move in and out. This surround has been in since 1991.
Old 02-02-2011, 07:40 PM   #5
Tileguy
Bud Cline's Avatar
Bathtub surround.
OK, that's a little better. Apparently you have a plastic tub surround attached at only the edges.
So now what?
Old 02-02-2011, 07:53 PM   #6
Bathtub surround.
Yes, so can I remove the wall surrround, leave the tub surround, and install tile in place of the wall surround?
Old 02-02-2011, 10:26 PM   #7
Tileguy
Bud Cline's Avatar
Bathtub surround.
...so can I remove the wall surrround, leave the tub surround, and install tile in place of the wall surround?
Depends on what you find for wallboard under the surround plastic. If it is drywall (and it most likely is) you can not install tile directly to the drywall, but there are ways to remedy that situation.
Peel the plastic and let's go from there.
Bathtub surround - quarter round? jarleifvaagen Remodeling 1 08-26-2010 10:16 PM
Bathtub Surround dion Plumbing 8 07-28-2010 07:25 AM
Bathtub surround???? organick Tiling, ceramics, marble 2 09-11-2009 09:00 PM
Gap in Corner Between Tub Surround and Bathtub? Howitzer Remodeling 12 09-17-2008 05:14 PM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 11:42 AM
