Old 09-12-2006, 11:45 AM   #1
Bathrrom Tile, Plaster
The tile around the bathtub have begin to loosen and fall off. I’ve removed several rows where the knobs and faucet are and found that the plaster is breaking away from the lath. I had planned on removing and replacing all of tile. I purchased backer board hoping I would be able to screw them on to the studs for retiling. I’ve found that my bathroom does not have stubs, the walls are plaster. (old apt. building) Is there anyway to attached the backer board or will I have to re-plaster the entire bathroom (5 X 7) if so is this a DIY job, or should I spend to have a contractor do the job.
Quinnman is offline   Reply With Quote
Old 09-12-2006, 08:43 PM   #2
What is the lath nailed to?
redline is offline   Reply With Quote
Tile over Tile ?? Piney Flooring 17 02-06-2012 10:59 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 04:31 PM
Subway tile installation bigboyjoel Flooring 3 08-02-2007 08:15 AM
Tile roof questions/repairs help please xoroniox Roofing 3 12-17-2006 03:02 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 03:14 PM
