Bathroom Walls - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-12-2009, 12:06 PM   #1
Joe F's Avatar
Rewards Points: 294
Bathroom walls
I'm in the process of putting up walls in my new basement bathroom. There will be a tiled shower, the rest of the walls will be paint. Please tell me if I have the process right:
Shower walls will be DuRock coated with Redgard (or is tile backer the thing to use in a shower). The rest of the walls and ceiling will be DensShield painted with mold inhibiting paint.
Is there more I need to do or a better product to use?
If you don't stand behind our troops, please feel free to stand in front of them.
Joe F is offline   Reply With Quote
Old 06-12-2009, 01:49 PM   #2
Rewards Points: 5,336
The products you mentioned for the shower are used interchangeably. Redguard is mentioned quite a bit as a waterproofing barrier. I've used kerdi myself a few times in the last year. Can't really say one is better then the other. Both are supposed to do the job.
What thickness cement board did you use? Hopefully 1/2".
Ron
Old 06-12-2009, 02:50 PM   #3
Joe F's Avatar
Rewards Points: 294
I probably mispoke. By "in the process" I mean I'm getting ready to start the walls. Haven't put anything up yet. I also saw a backer called Fiberock that looks to be the same as DenShield. Do you put Redgard or Kerdi over these too?
Old 06-12-2009, 03:19 PM   #4
The only backer I use is cement board with kerdi. Never heard of Fiberock. I'll check on it,just out of curiosity.
Ron
Seems similiar to hardiboard.
Old 06-12-2009, 04:10 PM   #5
Registered User
Termite's Avatar
Cement backerboard is a good traditional way of doing things. Redguard is ok, Kerdi is great. Either will work just fine. Don't forget to fill the seams with thinset and tape them with backerboard mesh tape....Very important step that DIYers often overlook. In the rest of the room there's no reason you can't use good old green board.
Old 06-12-2009, 06:52 PM   #6
Registered User
Rewards Points: 526
One is cement board, which wicks water like a sponge. One is gypsum based, which disintegrates in water. One relies on the installer to get the thickness correct, the other is fiberglass mat protected. One needs a vapor barrier behind it, one doesn't.
Scroll down to "Interior coverings": http://www.panhandleinsulation.com/b...materials.html
Compare them, read the bottom lines: http://www.jameshardie.com/pdf/backe...rison-half.pdf Be safe, G
Old 06-13-2009, 05:49 AM   #7
Joe F's Avatar
Rewards Points: 294
Thanks KC. Is green board OK to use for the ceiling in the shower area?
I just noticed your sig. I know an electrician that always says "the code is the worst job you can do and get away with it"
I'm concerned about the moisture build up on the bathroom walls -Any advice? JayBird General DIY Discussions 15 04-07-2009 10:25 AM
Mold on bathroom walls kliving General DIY Discussions 6 10-15-2008 08:11 AM
12x12 tile on small bathroom walls???? trueform General DIY Discussions 4 06-23-2008 11:34 PM
Bathroom walls MystiLatte Flooring 1 04-21-2008 05:47 PM
Bathroom Ceiling and Walls. Drywall ok? atilla137 Building & Construction 11 10-26-2006 03:32 PM
