Bathroom Vent Van Roof Flashing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-11-2012, 02:42 PM   #1
JOATMON
ddawg16's Avatar
Rewards Points: 1,500
This is sort of plumbing...sort of roofing....so I figure this is a good a place to ask...
I need to install a roof vent for my new bathroom vent fan.
Going on a typical 5:12 pitch asphalt shingle roof. Any issues with these units? The flashing flange seems a bit small compared to the taller vent flashings (you know, those ugly ones that looks like half a pipe on it's side.)
I already have the shingles off in this area so I'll be able to the tar paper on top of it....I just wish the flange was larger..
Any better suggestions? In my area...not that much rain...but when we do get it...we usually also have a lot of wind.
http://www.homedepot.com/buy/bath/ba...kit-66750.html
Old 07-11-2012, 03:00 PM   #2
AGWhitehouse's Avatar
I installed two of those units on my roof two years ago and I've had no issues at all even with a tropical storm and ridiculous freeze/thaw winter...had bad ice dams at the gutters, but the vents didn't leak a drop
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 07-11-2012, 03:03 PM   #3
Rewards Points: 13,468
I've also never had an issue with them. If it makes you feel better add some sealer under it before you install it and even add some window tape starting at the bottom then the sides and one across the top.
Old 07-11-2012, 03:19 PM   #4
JOATMON
ddawg16's Avatar
Thanks...
Good idea....certainly can't hurt.
New Roof marknok Roofing/Siding 4 08-06-2011 11:41 AM
Roof ventilaton - hip roof (ridge vent, fan, power vent ?) rkpatt Building & Construction 2 06-02-2011 04:21 PM
new roof, ridge vent was in est, but not installed... Zel1 Roofing/Siding 29 09-01-2010 04:30 PM
Roof Vent Cap Flashing??? Need advice. revamped Roofing/Siding 2 07-05-2008 11:01 PM
Bathroom Vent Not Vented to Outside / Would need to vent through flat roof House_Amuck HVAC 5 03-30-2007 09:57 AM
