Bathroom Vent Fan Into Soffit?? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-25-2009, 08:43 AM   #1
bathroom vent fan into soffit??
I'm adding a bathroom upstairs, and am trying to find a good place to vent the fart fan. The entire upstairs is a cathedral ceiling that is going to have spray foam insulation - so no roof vents. As such, the soffits are not venting into the non-existant attic space. Is it OK to vent the bathroom into the soffits? The soffits will be perforated.
thanks
red86yota is offline   Reply With Quote
Old 03-25-2009, 12:43 PM   #2
exhaust fan vents to fit the 4" ducting typical in this application are available that install to the soffit. These vents ensure the exhuast air exits external to the soffit - not into the soffit structure, which given the warm, moist air's propensity to rise would ensure wet and moldy decking and rafter tails. Ice dams would also be a concern if in a northern climate.
Does the cathedral ceiling assembly provide sufficient thickness to pipe the air to a roof penetrating vent?
Vents of both variety are available for inspection at any big box store.
rizzo is offline   Reply With Quote
Old 03-25-2009, 08:17 PM   #3
In some cases a roof vent is easier than a soffit vent! If you have a truss roof you will be OK! However, if you have a stick framed roof, like mine,there's little space to run the pipe between the top wall plate and the roof sheeting!
Old 03-25-2009, 09:15 PM   #4
Rewards Points: 150
I used soffit vent along with stick built roof, it was tight, had to flatten the pipe a little bit but it works
johnnyboy is offline   Reply With Quote
Old 03-26-2009, 08:48 AM   #5
Registered User
Termite's Avatar
Going through the soffit is fine, but the vent must terminate to outdoor air and must not be just dumped into the soffit itself.
Old 03-26-2009, 09:47 AM   #6
thanks everybody...i need to go hunt down some soffit vents that will work for me.
Bathroom vent directly over a rafter Kirgan Roofing/Siding 6 03-11-2009 01:30 AM
Venting bathroom vent thru dryer duct jredrocker HVAC 2 09-27-2008 10:25 PM
can I 'patch in' a bathroom vent into my kitchen's stove hood vent? joeyboy HVAC 2 09-10-2007 12:36 PM
Another Ridge Vent, Gable vent and soffit question (??) davco Roofing/Siding 2 04-30-2007 11:14 PM
Bathroom Vent Not Vented to Outside / Would need to vent through flat roof House_Amuck HVAC 5 03-30-2007 09:57 AM
