Bathroom Vent Code - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-02-2013, 05:34 PM   #1
Rewards Points: 28
Bathroom vent code
The vent for my bathroom fan in the basement is currently vented with a "T" duct along with my dryer to one vent outside. It seems to me this is not code? Also, it's a fairly lengthy span of duct for the bathroom fan. Is there a max length of duct work for a bathroom fan vent? Thanks for any help in advance.
dmack7 is offline   Reply With Quote
Old 03-02-2013, 05:54 PM   #2
DIY staff
Rewards Points: 7,174
T into a dryer vent is a huge violation----
Duct length and type of material for the bath fan? Good question---Gary in WA will know,I bet---
Old 03-02-2013, 06:00 PM   #3
There are 160 apartments in my building and only two exhaust fans for them all, so I don't think there's a maximum length. There are laws about how many hours per day the exhaust is working and how strong it has to be, but I don't see why duct length should matter.
And I wish someone cared about the rules that do exist because the exhaust fans in my building are constantly breaking and they've been down for about a month. They should require indicator lights in a part of the building visible to tenants because apparently I'm the only tenant who notices and cares when they're not working.
(the laundry room has its own exhaust in my building)
Dorado is offline   Reply With Quote
Old 03-02-2013, 07:23 PM   #4
Registered User
Rewards Points: 526
Thanks, Mike! The problem is; lint will collect on the (extra) moisture on the pipe walls from the bath. They require separate ducting, per minimum code; no mixing of systems (1502.1) last page; http://www.codecheck.com/cc/ccimages...6th_Sample.pdf
More dryer safety; http://www.ashireporter.org/HomeInsp...st-Systems/161
Use a Type "A" termination dryer hood, not "B"; http://www.appliance411.com/faq/dryer-vent-length.shtml
The bath fan manufacturer may have duct length limits, check with them; http://inspectapedia.com/interiors/B...entilation.htm
Gary
Old 03-02-2013, 07:24 PM   #5
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,248
there is a minimum for how much air is drawn out of the room by the fan.. as for duct length it can be an issue. .if the run is extremely long and hte pipe isnt insulated the warm moist air can condensate along the way out then start to drip on the ceiling drywall which can cause mold
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
oh'mike (03-02-2013)
Bathroom Vent Condensation staining ceiling MurphyMan HVAC 11 01-26-2013 02:45 PM
bathroom fan vent exit? treerat Roofing/Siding 1 03-11-2011 01:59 AM
Basement Bathroom, Would the Following be Okay by Code?? MikeCalg Plumbing 2 08-06-2010 08:49 PM
Attic Ventilation Question handy man88 Roofing/Siding 10 02-12-2010 10:50 PM
How to cut vinyl siding to vent bathroom fan? db_9 General DIY Discussions 9 11-13-2009 12:58 AM
