Bathroom Subfloor Best Practice - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-17-2008, 09:51 AM   #1
weekend warrior
Hobb3s's Avatar
Bathroom subfloor best practice
I'm currently in the middle of a bathroom reno, and I'm at the point where I'm just about ready to lay a new plywood subfloor over the existing floor boards (50's style). I've read that pressure treated is the way to go, for bathrooms which sounds reasonable. As I've never done this before, my question is should the sub floor cover the entire floor, including underneath where the tub is going to be, or should it just butt up against the tub and leave the tub on the floor boards?
When I tore the old floor it was just up to the tub but not underneath.
Hobb3s is offline   Reply With Quote
Old 04-17-2008, 03:36 PM   #2
BuilderRemodeler
Cement Board is also as good choice over your subfloor.
BuilderRemodeler
40 pages of useful Home Remodeling Charts, Home Addition Guidelines, Home Painting Tips, How to Determine a Deck Size and Build Your Deck Online! www.BrandsConstruction.com
www.HomePlansForFree.com One Story Ranch Detailed Free Home Plans
darylbrands is offline   Reply With Quote
Old 04-17-2008, 04:15 PM   #3
Registered User
Termite's Avatar
Absolutely no need to use treated plywood for the subfloor. In years of inspecting, I have yet to see anyone do that. Treated plywood is made with the same "exterior grade" glue that regular plywood is, and that glue will fail and cause the treated plywood to de-laminate just as fast as it will in non-treated plywood. Treated plywood is still for interior use, but is required when used up against concrete walls and floors.
Use 3/4" T&G floor sheathing and glue and screw it down. Then lay 1/2" cement backer board (wonderboard, hardiboard, etc). Then tile.
Common practice these days it to set the tub on top of the floor sheathing, and cut a hole for the trap plumbing. Actually, either way is ok. If you're replacing the tub with a fiberglass or acrylic unit, it is common to bed the tub in mortar, so you'd need the floor sheathing for that.
Old 04-18-2008, 02:27 PM   #4
weekend warrior
Hobb3s's Avatar
Fantastic! Thank you for the comprehensive response, very much appreciated. Yes, we are replacing the tub with a new acrylic one. Thanks again.
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 03:34 PM
Basement Bathroom Circuit design drtpdee Electrical 6 01-03-2008 10:10 AM
Second level / attic bathroom size moneymgmt General DIY Discussions 2 05-02-2007 07:32 AM
Wiring electric heater in bathroom PatSea Electrical 5 01-06-2007 09:40 PM
