Bathroom Subfloor (Basement) - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-30-2011, 11:03 AM   #1
Rewards Points: 640
bathroom subfloor (Basement)
I am getting very close to doing my basement bathroom floor, my basement is done with dricore, HOWEVER, my bathroom we want stone tile, and you can not dricore then put stone tile over it... so the basement is 7/8" higher everywhere then the bathroom, I am looking for a fix to this... was wondering if this idea would work...
(note: i do not want to use self leveling concrete, I've had nothing but bad luck, and if I ever redid the basement again I'd have a much higher spot if dricore was ever ditched)
my idea right now is to put 1/2" or 3/4" ridgid foam down then put a plywood subfloor over that, tapcon that down, ditra over it then tile
good idea? bad idea? other ideas?
BlueBSH is offline   Reply With Quote
Old 11-30-2011, 01:07 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Why not glue down a couple layers of hardibacker?
titanoman is offline   Reply With Quote
Old 11-30-2011, 01:09 PM   #3
Rewards Points: 640
I was told in the past that is a bad idea
Old 11-30-2011, 01:11 PM   #4
Disabled wood vet
titanoman's Avatar
You might be right? Why?
Old 11-30-2011, 01:13 PM   #5
Rewards Points: 640
no idea, someone on here told me that in the past
Old 11-30-2011, 01:50 PM   #6
Disabled wood vet
titanoman's Avatar
Maybe trapping moisture would eventually cause the glue to fail. Use tapcoms too. I don't know. I'm just a carpenter, nota tile guy.
Old 11-30-2011, 07:45 PM   #7
Rewards Points: 640
no one else that has expiernce in this?
Old 11-30-2011, 07:48 PM   #8
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You want a voice-of-experience?
DON'T DO IT!
Old 11-30-2011, 07:49 PM   #9
Rewards Points: 640
DON'T DO IT!
and the reason not to is? sorry but "dont do it" is never enough for me, I like facts and reasons behind ideas especially when building science says its an ok idea
http://www.buildingscience.com/docum...g-your-basment figure 1 is the idea I was going for
Old 11-30-2011, 07:54 PM   #10
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Natural stone tile installations require double the strength of the substrate as what is required for regular ceramic tile. Natural stone tiles have imperfections and faults built in and require a solid base for installation.
Foam board ain't the answer. Especially foam board with plywood Mickey Moused over the top of it. The foam board will give, the plywood seams will rock and roll, the stone tile will remove itself in no time.
There how's that?
DON'T DO IT!
Old 11-30-2011, 07:57 PM   #11
Rewards Points: 640
There how's that?
DON'T DO IT!
Thanks for the explination, only way to learn is to get the reason why!
What about skipping the stone tile and going with ceramic or a floating ceramic? but using the same flooring system (xps then ply)
Old 11-30-2011, 08:03 PM   #12
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Same problem. Self demolishing grout. A urethane grout might hold up.
What about a floating ceramic?
Same problem. You could try Snapstone, it comes with its own urethane grout but I would be more comfortable with the tile adhered to the substrate. But then, the major issue is the substrate.
I still have a suggestion, wanna hear it?
Old 11-30-2011, 08:26 PM   #13
Disabled wood vet
titanoman's Avatar
I still don't know why my hardibacker idea won't work. Anybody?
Old 11-30-2011, 08:27 PM   #14
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Go ahead and do it and you'll see why it won't work.
Have you ever attached any cement board to concrete?
Old 11-30-2011, 08:30 PM   #15
Disabled wood vet
titanoman's Avatar
What the heck kind of an answer is that?
multiple choice - basement bathroom venting debacle and burps denemante Plumbing 1 11-15-2011 10:50 AM
Bathroom to Laundry Room to Bathroom bcatanz10 Remodeling 2 10-10-2011 09:45 PM
Wondering if it makes economic sence to replace a bathroom exhaust fan ChrisJJ HVAC 0 06-14-2011 10:36 AM
How to select appropriate Bathroom Lighting crescentharbor1 Kitchen & Bath Remodeling 1 02-28-2011 09:47 PM
Basement bathroom wiring mess. Little help. trailblazer1229 Electrical 15 02-16-2010 09:29 AM
