bathroom subfloor (Basement)
I am getting very close to doing my basement bathroom floor, my basement is done with dricore, HOWEVER, my bathroom we want stone tile, and you can not dricore then put stone tile over it... so the basement is 7/8" higher everywhere then the bathroom, I am looking for a fix to this... was wondering if this idea would work...
(note: i do not want to use self leveling concrete, I've had nothing but bad luck, and if I ever redid the basement again I'd have a much higher spot if dricore was ever ditched) my idea right now is to put 1/2" or 3/4" ridgid foam down then put a plywood subfloor over that, tapcon that down, ditra over it then tile good idea? bad idea? other ideas? |
Why not glue down a couple layers of hardibacker?
no one else that has expiernce in this?
DON'T DO IT! |
and the reason not to is? sorry but "dont do it" is never enough for me, I like facts and reasons behind ideas :laughing: especially when building science says its an ok idea http://www.buildingscience.com/docum...g-your-basment figure 1 is the idea I was going for |
Natural stone tile installations require double the strength of the substrate as what is required for regular ceramic tile. Natural stone tiles have imperfections and faults built in and require a solid base for installation.
Foam board ain't the answer. Especially foam board with plywood Mickey Moused over the top of it. The foam board will give, the plywood seams will rock and roll, the stone tile will remove itself in no time. There how's that? DON'T DO IT! |
What about skipping the stone tile and going with ceramic or a floating ceramic? but using the same flooring system (xps then ply) |
I still have a suggestion, wanna hear it?:) |
I still don't know why my hardibacker idea won't work. Anybody?:whistling2:
Go ahead and do it and you'll see why it won't work.:)
Have you ever attached any cement board to concrete? |
| All times are GMT -4. The time now is 10:48 PM. |
