Bathroom Shower Floor Installed Wrong! - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-07-2010, 07:44 AM   #1
Unhappy
Bathroom Shower Floor installed wrong!
My contractor installed a neo-angle shower. But the acrylic floor has been pooling water since the first day of installation. And it has that unstable feel of one of these you try out at a Home Depot.
The contractor claims he can fix this by removing the wall tile, maybe some of the floor tile and lifting the neo angle floor and resetting it. He claims it happened due to settlement.
I am concerned that he could make things worse, damaging the neo angle, the wall and floor tiles, etc.
Can it be fixed?
Should I be concerned about damage?
newbathroomguy is offline   Reply With Quote
Old 11-07-2010, 08:58 AM   #2
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
do you have access from underneath?
tcleve4911 is offline   Reply With Quote
Old 11-07-2010, 09:04 AM   #3
No access; the only way to get under is to lift out the neo
that also requires taking down the glass doors.
Another question is, when the shower water hits the angle where the door meets the glass wall, water escapes.
Is that what we should expect?
Old 11-07-2010, 09:11 AM   #4
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Hell no
He's either botched the bottom door sweep or clogged the weep holes.
Old 11-07-2010, 09:15 AM   #5
Uggh!
So no easy solution for the neo either?
Old 11-07-2010, 09:16 AM   #6
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Don't know yet
Do you have access from below?
Old 11-07-2010, 09:20 AM   #7
no access from below without taking out a ceiling downstairs
Old 11-07-2010, 09:28 AM   #8
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
The reason I ask is addressing the floor situation first.
okay....do you have an access panel that lets you gain access to the space between the shower floor and the subfloor?
Old 11-07-2010, 09:35 AM   #9
no such access exists
Old 11-07-2010, 09:36 AM   #10
www.No-Curb.com
JohnFRWhipple's Avatar
Thoughts..
Take it out and re set it.
I bet you find spray foam or concrete underneath this shower pan...
That or the extension from the drain was cut a 1/4" long and is pushing up off your PTrap.
No easy fix.
Just re do it...
Good Luck
JohnFRWhipple is offline   Reply With Quote
Old 11-07-2010, 09:40 AM   #11
I did not see it get installed, but I know there was a styrofoam template that came with it; I think that is what is underneath
Tags
shower neo floor water
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Framing Shower Wall in Bathroom Justin LaRue Kitchen & Bath Remodeling 2 06-30-2009 10:34 PM
What kind of wall for tiling bathroom and shower ghostdog Remodeling 1 03-26-2009 05:17 AM
Sorta waterproof window for OVER a tub shower bathroom justdon Remodeling 5 09-16-2007 08:27 PM
Bathroom Shower jackco711 Flooring 4 11-14-2006 09:22 AM
