-   -   Bathroom Shower Floor installed wrong! (http://www.diychatroom.com/f19/bathroom-shower-floor-installed-wrong-86027/)
newbathroomguy 11-07-2010 07:44 AM
My contractor installed a neo-angle shower. But the acrylic floor has been pooling water since the first day of installation. And it has that unstable feel of one of these you try out at a Home Depot.
The contractor claims he can fix this by removing the wall tile, maybe some of the floor tile and lifting the neo angle floor and resetting it. He claims it happened due to settlement.
I am concerned that he could make things worse, damaging the neo angle, the wall and floor tiles, etc.
Can it be fixed?
Should I be concerned about damage?
tcleve4911 11-07-2010 08:58 AM
do you have access from underneath?
newbathroomguy 11-07-2010 09:04 AM
No access; the only way to get under is to lift out the neo
that also requires taking down the glass doors.
Another question is, when the shower water hits the angle where the door meets the glass wall, water escapes.
Is that what we should expect?
tcleve4911 11-07-2010 09:11 AM
Hell no
He's either botched the bottom door sweep or clogged the weep holes.
newbathroomguy 11-07-2010 09:15 AM
Uggh!
So no easy solution for the neo either?
tcleve4911 11-07-2010 09:16 AM
Don't know yet
Do you have access from below?
newbathroomguy 11-07-2010 09:20 AM
no access from below without taking out a ceiling downstairs
tcleve4911 11-07-2010 09:28 AM
The reason I ask is addressing the floor situation first.
okay....do you have an access panel that lets you gain access to the space between the shower floor and the subfloor?
newbathroomguy 11-07-2010 09:35 AM
no such access exists
JohnFRWhipple 11-07-2010 09:36 AM
Thoughts..
Take it out and re set it.
I bet you find spray foam or concrete underneath this shower pan...
That or the extension from the drain was cut a 1/4" long and is pushing up off your PTrap.
No easy fix.
Just re do it...
Good Luck
newbathroomguy 11-07-2010 09:40 AM
I did not see it get installed, but I know there was a styrofoam template that came with it; I think that is what is underneath
