Bathroom Shower In Basement Along Foundation Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-16-2009, 11:56 AM   #1
bathroom shower in basement along foundation wall
I wanted to know what everyone things about how to go about this. I have the pan located in the basement the will intersect 3/4 of glass block window. I would like to keep the window but wasn't sure about going about this. The entire wall system will have 1" XPS foamBoard with a 2x4 wall with 1" gap from foam. I plan on using using 2 layers of 2" foam on lower 1/4 of stud wall and kraft faced on upper and no vapor barrior and using paperless drywall. The questions is about the window in the shower. I am going to frame it so it looks like in the pic but should I put a 30lb felt on before the durock and tile? I know that would be a double vapor barrier in that area. How do I get around sealing the window? I am going to tile the inside of the window. Do I insulate at all behind the shower wall? Should I just call it quites and cover the window? I wanted some natural light since it is a basement. Thanks everyone.
bathroom shower in basement along foundation wall-img_0001.jpg   bathroom shower in basement along foundation wall-img_0001a.jpg   bathroom shower in basement along foundation wall-img_0001c.jpg
jeeper is offline   Reply With Quote
Old 04-16-2009, 07:20 PM   #2
CrossWorks's Avatar
Rewards Points: 150
First thing I would do is move the light I'm sure you knew that.
But seriously; insulation behind the wall wouldn't hurt. The 30lb felt I don't feel is needed. Finally, just bring your durarock and tile right up against the window and seal with silicone, you should be fine.
This looks pretty straight forward to me.
A great personality will open many doors in life,
but it's your character that keeps them open!
"Where Every Nail Has a Purpose!"
CrossWorks is offline   Reply With Quote
Will water lines freeze if placed behind insulated stud wall in basement? jpsmith Remodeling 22 03-05-2009 12:23 PM
Tile in Shower and on Wall of Bathroom jwhiteuwc General DIY Discussions 2 02-02-2009 08:21 PM
Venting basement bathroom fixtures ccathy247 Plumbing 1 11-01-2008 03:44 PM
~HELP~ Basement Wall is bowing earthad1 Building & Construction 6 06-05-2008 12:24 PM
Basement knee wall question vugger Building & Construction 2 01-05-2008 09:02 PM
