#1 |
Bathroom glass block removal issue
Hi all...very new to these forums, but I was looking for some help with my bathroom renovation.
I'm doing a full renovation down to the studs of my bathroom (house was built in 1944) and I want to install only two rows of glass blocks (preferably the top 2 rows) and close off the rest. If I made a T in there w/2x4's (one going horizontal to the floor, and the other going perpendicular), putting plywood & Tyvek on the outside, and insulation & drywall on the inside...I would then have someone come fill in the outside with bricks. Is that good enough? Attached are pics of both outside & inside to reference. Thanks, Peter |
#2 |
Tileguy
That plan should look pretty bad from the outside.
Why not remove/renew all the wood in the window and start over using glass blocks again to fill the entire area? |
#3 |
I feel the window area is a bit bigger then I would like. It's very cold to stand next to in the Ohio Winter...even with hot water on you. It's great for letting natural light in during the day, but I preferably don't want it that large.
#4 |
Tileguy
The outside of the home will never look like anything more than a boarded up window if you do what you are wanting to do. If you're happy with that look then I suppose you can do it.
#5 | |
Bathroom glass block removal issueQuote:
Thanks for your opinions. Always good to get another take on it.
#6 |
http://www.hy-lite.com/
install a new acrylic block window,less heat loss should make standing next to it much more comfortable |
#7 | |
| Display Modes | |
| Glass Block Window Install | dvaupel | Windows and Doors | 3 | 10-03-2011 11:13 PM |
| "Defogging" double-pane windows .... a gimmick?? | alexz | General Discussion | 133 | 03-10-2010 01:35 PM |
| Glass block windows | deck hand | Off Topic | 2 | 09-13-2009 06:15 PM |
| bathroom sink pressure issue. | tgamblin | Plumbing | 4 | 04-27-2009 01:21 PM |
| Glass block installation | Cossack | Building & Construction | 5 | 08-12-2008 04:52 PM |
