Bathroom glass block removal issue
2 Attachment(s)
Hi all...very new to these forums, but I was looking for some help with my bathroom renovation.
I'm doing a full renovation down to the studs of my bathroom (house was built in 1944) and I want to install only two rows of glass blocks (preferably the top 2 rows) and close off the rest. If I made a T in there w/2x4's (one going horizontal to the floor, and the other going perpendicular), putting plywood & Tyvek on the outside, and insulation & drywall on the inside...I would then have someone come fill in the outside with bricks. Is that good enough? Attached are pics of both outside & inside to reference. Thanks, Peter |
That plan should look pretty bad from the outside.
Why not remove/renew all the wood in the window and start over using glass blocks again to fill the entire area? |
The outside of the home will never look like anything more than a boarded up window if you do what you are wanting to do. If you're happy with that look then I suppose you can do it.
Thanks for your opinions. Always good to get another take on it. :) |
http://www.hy-lite.com/
install a new acrylic block window,less heat loss should make standing next to it much more comfortable |
| All times are GMT -4. The time now is 05:57 AM. |
