Bathroom In The Garage. Is This Dumb? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-01-2011, 03:30 PM   #16
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,216
Originally Posted by grabbag View Post
In regards to the heat or ac source. Is that typically a code requirement even if it is in the garage? I guess you could argue that it is not in the garage anymore. I would like to avoid running air to the room. I am in TX and I could see it getting warm in the Summer. The good thing is that the outside door and wall never face the sun.
Thanks.
Doug
Install a through the wall AC/heater combo. Turn on only when you need it. Smaller ones are only 120 volts.
Coastal South Carolina
Old 06-02-2011, 03:30 PM   #17
I was closing up holes that i made in the drywall on Saturday and it was 90+ outside. I noticed cool air blowing from the holes. My thoughts were there is an open duct blowing into the void between the ceiling and the upstairs floor.
I cut a hole in the ceiling so that I could take a look around. It was very refreshing to stick my head up there but I could not find any ducting. I looked through the attic and found nothing conclusive. After poking around, I figured out that HVAC had been run in the garage. The house has 2 units. It used to have threee, based on the breaker box. 'AC Unit 3' was scratched out and now shows 'open'.
So for now, I am going to put a vent on the hole in the ceiling and bring the cool air into the bathroom.
grabbag is offline   Reply With Quote
Detached garage subpanel options? jeffiebean Electrical 6 03-15-2011 08:20 PM
Garage remodel - adequate foundation? WillK Building & Construction 1 01-21-2011 01:50 PM
Insulate finished garage ceiling or condition garage? pasichnyk Building & Construction 19 12-06-2010 01:46 AM
Garage Ideas? tripflex General DIY Discussions 13 12-16-2009 07:06 PM
House and detached garage need new roofs looking for tips and advice jimtmcdaniels Roofing/Siding 3 11-06-2009 09:07 AM
