Old 10-04-2012, 11:41 PM   #1
Bathroom fan vent through roof --straight up?
I have a bathroom fan that needs to be vented through a hip roof. I am using rigid vent. I have the opportunity to pretty much go straight up to get through the roof, and it would be less than a 36" run.
Is it best to just go straight up?
Or should I run horizontally for a bit and then go straight up?
Thanks for any tips!
domh is offline   Reply With Quote
Old 10-05-2012, 12:12 AM   #2
Air exhausted from a bath can have relatively high dew point temperatures so if possible it's better if you can run it horizontal to the soffit with some down slope so the condensation in the pipe can drain to the outdoors in colder months.
Fairview is offline   Reply With Quote
Old 10-05-2012, 01:26 AM   #3
we ran ours straight up through roof but our run is only about 14inches
federer is offline   Reply With Quote
Old 10-05-2012, 07:05 AM   #4
For that short a distance as long as you insulate the pipe it will be fine.
I use PVC as the vent pipe so there's no rusting.
Old 10-05-2012, 07:27 AM   #5
In this application insulation is of little value without a heat source. We can look at the bath mirror condense at 75°F and have a good idea what a pipe in the attic at say 45° is going to do. Immediate water draining back unless the fan is way better than the ones I've seen.
Old 10-05-2012, 08:22 AM   #6
This is interesting. I didn't think of this. I have the same issue as the op of this thread and is an upcoming project.
Thanks!
JohnC20 is offline   Reply With Quote
Bathroom fan damper missing is roof vent damper enough?? wantboost HVAC 5 11-10-2011 05:29 PM
bathroom fan vent exit? treerat Roofing 1 03-11-2011 02:59 AM
Can I use one roof vent for 2 bathroom exhausts fans? P550 General Discussion 18 11-17-2010 10:15 AM
How to vent eaves if no overhang, metal roof, Texas? pj99 Roofing 7 06-04-2009 03:58 AM
can I 'patch in' a bathroom vent into my kitchen's stove hood vent? joeyboy HVAC 2 09-10-2007 01:36 PM
