Bathroom Fan - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-16-2008, 11:19 AM   #1
Bathroom Fan
Hi
I am replacing an old bathroom fan with a new fan. The old fan is a rectangle shaped therefore the hole in the ceiling is the same shape. The new fan is round. I included the pictures.
If I take a scrap drywall and cut to the same size of the existing opening and then cut a round opening, will the new drywall stay in tact without falling apart? The existing opening is measured 9"x7 1/4" and the new grille is 5 1/2" diameter. There won't be any weight from the fan and grille resting on the new piece of the drywall because the fan box will be screwed into the ceiling joist and the grille will be snapped into the fan box itself.
Furthermore, the motor is going to be mounted nearby and connect via insulated duct tube.
I can make the hold bigger so there is more area of the new piece to cut the round opening. I can also add 2x4 so I can nail the new piece into it for additional holding strength, if that is a needed step instead just spackle the piece into the hole.
Here are the pictures....
Thanks for helping me out.
Eagle2
Eagle2 is offline   Reply With Quote
Old 10-16-2008, 01:06 PM   #2
47_47's Avatar
Rewards Points: 44
I'd cut the existing drywall back to the joists and screw 2x2's to the sides of the joists for your new drywall support. I'd also secure pieces of scrap 1x perpendicular to the joists overlapping the existing and new drywall joints.
47_47 is offline   Reply With Quote
Old 10-16-2008, 01:48 PM   #3
home improvement guru
aaron.klimchuk's Avatar
cut out a larger section of drywall so you can properly attach it to the joists as stated above. While the fan itself looks like it doesn't weight too much, its better to be safe then sorry.
Last edited by AtlanticWBConst.; 10-25-2008 at 08:01 AM. Reason: Site Rules Violation: Business Web link Removed
aaron.klimchuk is offline   Reply With Quote
Old 10-16-2008, 04:06 PM   #4
I will go to home depot to change the fan to the same shape to save all the hassle...
Last edited by AtlanticWBConst.; 10-25-2008 at 08:01 AM. Reason: Site Rules Violation: Web link Removed
KUIPORNG is offline   Reply With Quote
Old 10-16-2008, 04:21 PM   #5
that works too...
Last edited by AtlanticWBConst.; 10-25-2008 at 07:58 AM. Reason: Site Rules Violation: Business Web link Removed
Old 10-16-2008, 08:55 PM   #6
Originally Posted by aaron.klimchuk View Post
that works too...
I like that idea too!
In either case, I would suggest using a piece of plywood secured to the joists.
It will support the fan and the drywall filler can be screwed to it also.
Old 10-20-2008, 05:44 PM   #7
umm...I never said I bought the fan from HD. It is Fantech so I ordered it. Beside I don't mind the extra work. It keeps me busy.
All is done. I just have to spackle the gap and nails, paint the bathroom and move on to our second bathroom.
Thanks for your ideas.
Eagle2
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 04:34 PM
Steps for Bathroom Remodel? SeattleHome Building & Construction 7 10-09-2008 12:04 PM
Basement Bathroom Circuit design drtpdee Electrical 6 01-03-2008 11:10 AM
